Chris NottAH Fabrications
    Mar 2010
    Cleveland, North East
    214
    2.0 PD170 TDI Engine Noise
    Recently I have been getting a weird noise from the engine, mainly at low speeds or when changing gear, almost like wastegate noise I guess.
    I did consider it may be a sticky VNT mechansim but the car drives ok, I'm not getting the usual random power delivery or any overboost errors that I have had previously with VNT issues on other VAG cars.
    Anything else to check that could make a similar noise?
    May 2014
    St Helens Merseyside
    44
    Add al_p on Facebook Visit al_p's Youtube Channel
    you could possibly be right thinking sticky vnt , is it like a turbo flutter noise when you change gear ?
    Mar 2010
    214
    yeah it is a kind of flutter noise.
    Mar 2010
    214
    Wonder if this is possibly the cause of my noise - had the flashing coil fault light on today and limp mode with error code P0299 (Underboost)
    I had a poke around and came across a fault with the intake manifold swirl flap actuator - I connected a vacuum pump up to it and couldn't generate any vacuum so I assume the diaphragm is split.
    https://www.youtube.com/watch?v=DkPS...ature=youtu.be
    Might not be the problem but I shall report back after replacing.
  1. 170 TDI odd engine noise - now with pics - turbo?
    By eddscott in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th December 2013, 19:44
  2. TDI engine noise
    By jimmp in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th December 2011, 10:42
  3. knocking noise in A4 TDI Engine
    By Paulw in forum Diesel forum
    Last Post: 31st March 2007, 18:48
  4. TDI engine noise
    By vwed1 in forum Volkswagen and other VAG
    Last Post: 23rd October 2004, 00:12
  5. Engine Noise in 4th and 5th
    By BiffS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th October 2003, 08:41
