Results 1 to 14 of 14
    imported_carjacker0
    s-line standard suspension setup
    could anyone answer a question about the b7 s-line standard rear suspension setup.? i have just got a new b7 sline with 18"rims [img]/ubbthreads/images/graemlins/1luvu.gif[/img]and it seems to be sitting high at the back so i was looking at the shocks and noticed two plastic bushes on the rod of the shock (one green the other yellow each about 30mm long and are just clipped on) and want to now are these standard items or where they just forgotten to be taken off after delivery.any ideas would be helpful. [img]/ubbthreads/images/graemlins/book.gif[/img]The car has a very hard setup compared to my previous b6 and have about 400 miles done now so everything should have settled by now.
    Mar 2006
    Lanarkshire Scotland
    Re: s-line standard suspension setup
    Just had a look at my B7 S-line. Had it parked next to a work mate today and noticed his suspension was lower than mine (same models).
    Checked tonight and I also had the bushes you described, however only on the one side (drivers rear). I've removed them and hope the suspension settles a bit as a result.
    Is yours any better - since the removal? Did you have them on both sides?
    Mark
    imported_carjacker0
    hi there ,i had them on both sides and since removed has made a world of difference to the ride quality [img]/ubbthreads/images/graemlins/jump.gif[/img].As mentioned elswhere these spacers should have been removed on pre delivery inspection but also makes you wonder what else was missed .Does anybody know what the full inspection consists off?. [img]/ubbthreads/images/graemlins/book.gif[/img]
    Mar 2006
    Just had all four wheels off the car and found another one wedged on the drivers front side.
    Had the car for six months and had thought the suspension was useless on anything but the smoothest of roads.
    can't understand why they would ony remove these from one side of the car. In fact don't understand what purpose they serve full stop.
    Think anyone taking delivery of a new B7 or any other model for that matter should make this there first point of check. I had read your post previously, as I thought my setup was a bit harsh I had checked the passengers side of the car (which didn't have the bushes). Was only after seeing the difference next to my mates that made me re-visit.
    Anyway hopefully nothing else has been overlooked.
    Mark
    KoFidee's Avatar
    S-LINE
    Mar 2003
    EAST RIDING OF YORKSHIRE
    146
    you got a picture of them?
    thxs
    looked at mine best I could with wheels onbut cannot see anything will whip wheels of later to check
    jonmusicman's Avatar
    Nov 2005
    Staffordshire
    176
    Any chance of someone posting a photo showing these bushes and where they are on the car?
    [img]/ubbthreads/images/graemlins/idea.gif[/img]
    Mar 2006
    Had to rake through the dustbin to find this. Here's the link.
    http://i71.photobucket.com/albums/i1...s/HPIM0439.jpg
    There were two bushes on the back, one identical to this and a larger green bush about 50mm thick. This one came of the front.
    Look under the rear wheel arch at the shock. Your actually looking at a sleeve which covers the rod, at the top of the sleeve there's an orange rubber damper and the bushes will be sitting on top of this if you have them.
    Mark
    KoFidee's Avatar
    S-LINE
    Mar 2003
    146
    can you see this with car on ground or does it need jacking to extend the rear top expose the bush if still there
    thxs for piccy.
    i see yellow sleeve on shocks
    its above this yeah?
    Mar 2006
    You should be able to see with it on the ground, although I had to get in there with a torch. I've taken a picture of the rear shock, notice the orange rubber Bush, if you have them they'll be sitting on top of this.
    Nov 2005
    UK
    44
    [ QUOTE ]
    [/ QUOTE ]
    Its not undone for the rear transit cones to be left in place after the pdi. Well done for dealing with it!
    imported_stranks
    Just checked the pre-delivery inspection checklist for my 18 month old cab and these are not mentioned.
    So I guess this is an internal checklist
    I have ordered a new cab and delivery will be in mid July (once the 2.0T S-Line manual option is available for order) I will definetley ask the dealer regarding these bushes. Good pointers guys. [img]/ubbthreads/images/graemlins/ok.gif[/img]
    Dec 2006
    Smile More Transit blocks/bushes left in place
    Thanks for the advice left on this thread. Noticed my new 2.0T avant ride was hard, particularly at rear and rear was riding high. Checked the shock absorbers as indicated here. Yellow and green blocks/bushes in place. Stopped by Kwik-Fit (local and handy) removed in 1 min (no charge) and on my way. Car feels much better. No bushes apparently left in place on front shocks.
    I will discuss with the dealer ...
    master mariner.
    Jan 2011
    Wiltshire
    22
    Quote Originally Posted by master mariner View Post
    master mariner.
    So much for the PDI Checks that are ment to be carried out.It also appears to be a common error that goes across a lot of Marques ?!?!?! It would be intresting to ask for the PDI check sheet [ it is a chargeable cost - not sure if its to the customer or the manufacture - or both!!]
    past cars : Leons 1P x 2 Tdi and TSI, Lotus Cortina, Fiat Abarths 750 tc x 2, E Type Jaguar, Steyer Puch TRII, NSU 1200TT
    lespaul's Avatar
    Dec 2010
    Oxfordshire
    59
    I have just paid to have my rear shocks replaced as the ride height is low on the passenger side on the rear. I know ride height is not effected by the shocks. But I can only go by what Audi tells me. I'll see if these are on them at all as the ride is a little harsh and still low on the rear on one side
