Volks AutosAH Fabrications
Results 1 to 18 of 18
    Quattrodude's Avatar
    Jan 2014
    Manchester
    51
    Air con- Compressor goosed
    Had my air con looked at today due to no cold air.
    Plenty of gas apparently but compressor is dead.
    The tech showed me the static bolt as the pulley turned and explained that a new unit as well as a total system flush and other new bits and bobs would be needed, due to metal fragments, being sucked through the system, all for the princely sum of £900!!
    He said he wouldn't bother, considering it's a 2005 and the value of the car.
    He's got a point but I can't bear being in a hot car with leather seats during one of the rare heat waves we get lol.
    Anyone else had this problem and what did it cost you to fix?
    A4 2.0T Avant S-Line Quattro, room in the boot for a leisurely lifestyle
    csm
    Jul 2013
    30
    I seriously wouldnt bother lets be honest, its not gonna be soooo hot that putting the windows down wont do the trick
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I had a goosed compressor and just got a sourced one from a scrappie. £75 and another £50 for a recharge.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    If it were me, I'd get it repaired, although like Wrath said, try to source a used part rather than a new one. If you're planning to keep the car in the medium term, you're gong to want it working. And if you're not planning to keep it, it'll be an unattractive proposition to potential buyers if the air con isn't working.
    That figure of £900, is that Audi dealer prices, or independent garage prices?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Oct 2013
    373
    Ive said to the wife many times to get things fixed, she always said why I dont need it?, Ive always replied yes but a buyer will want to see it working so why not fix it now and you get to use it rather than fix it just to sell it.
    I would say second hand pump, get it fitted then slide off to quick fit/ats etc for one of their cheap regas jobs, dont mention new pump etc then see how it goes.
    2005 car has still got a value even if its done big miles
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    Quote Originally Posted by lynallbel View Post
    Spot on. It's the ones on which things don't work that have little value, because it shows the car has been neglected.
    Tim@G's Avatar
    Apr 2013
    26
    I had the air con on my 2005 avant sorted last year, cost me about 220 quid for compressor and pressure sensor. my dad managed to get me the compressor for trade price and gassed it for me foc. Audi had previously quoted 700quid for the same job.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    Do an eBay search. There's loads on there.
    Molnboman's Avatar
    The old aircon is handy when it's wet and cold too....not just for Summer. It does clear the moisture out of your cabin when it's working and stops the windaes misting up. There is company in the Northeast of England where I bought my compressor for my Zafira and their prices and service was really good.....think they are on ebay.
    BR
    A
    G_Shail's Avatar
    Audi A4 Cabriolet
    Apr 2014
    Bristol
    70
    I'm a air conditioning engineer but don't deal much with car a/c but £900 is a total joke source one yourself gas recharge can be found £35
    G_Shail's Avatar
    Audi A4 Cabriolet
    Apr 2014
    Bristol
    70
    I would get it fixed as you would want this if you ever came to sell it
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    just about, right here!
    3,755
    Get it fixed i say!
    The a4 climate control on auto was great on the avant!
    Plus easier to sell later on if functional!
    The key to healthy air con is never turn it off! (for future reference) there designed to be always on!
    Start turning off, bacteria builds up and drains block up and the clutch plays up!
    and don't use that econ button, it bypasses the air on leading to an econ button that cant be switched off!
    G_Shail's Avatar
    Audi A4 Cabriolet
    Apr 2014
    Bristol
    70
    I keep mine on all the time in my A4 cabriolet , keep it all working and clean , I do keep up regular checks but I suppose it's easy as it's bread and butter as it's my job !
    Oct 2013
    373
    Wife has always ran with hers on all the time no matter what car she had
    Me I would be chuffed if mine had a/c
    May 2012
    Kings Lynn
    910
    I managed to Part ex my old 2.0TDI avant with air con not working and EML on lol.
    Current - 2006 B7 A4 S Line Saloon 2.0T TFSI Special Edition, Unicorn stage 1 remap, Metallic Dolphin Grey, 18" TTRS Rotors, Ferrari Red front/rear Calipers, 3.5" Powerflow tailpipes, BOSE, Cupra R splitter, Chrome grille slats, S4 Mirror covers, Black/silver leather interior, Debadged, Arm rest delete, LED plate lights, Dectane LED Red/Crystal tail lights, HID 6k, RS 4 pedals, Rev D D/V, APR snub mount, NGK 7s
    Gone - 2005 B7 A4 Avant 2.0 TDI
    North East
    607
    Quote Originally Posted by Tim@G View Post
    Audi Teesside charged Audi Uk £860 to replace my Compressor (first time it failed under warranty five years back ).
    Jan 2014
    Manchester
    51
    Well it's been pretty hot recently, but nice and breezy. I went away in the car camping this weakend and didn't miss the A/C that much but agree that if it rained it would be a different story.
    Also agree with the selling on factor. I'm thinking of getting a reconditioned compressor, but what about the other parts that could have been affected if the metal fragments have been sucked through the system?
    Oct 2013
    373
    Change the dryer as well as that will filter any crap out, so hopefully caught any bits
    On the trucks at work when a compressor blows, its gets a new compressor a vac down and regassed and thats it.
    My daily land rover doesnt have a/c its a dark colour I hate the sun its a ****ing nightmare, get in the really old one its a light colour much better
  1. Air con compressor part no. Help please
    By hooley in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2007, 22:43
  2. A2 Air Con Compressor
    By shollis in forum A2 forum
    Last Post: 6th May 2007, 22:39
  3. AIr Con Compressor A4 1.9 TDI
    By in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th July 2005, 09:59
  4. Air Con Compressor
    By Tiger6791 in forum General Technical / How To
    Last Post: 19th October 2004, 21:47
  5. Air Con Compressor
    By Tiger6791 in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th October 2004, 21:56
