Hi All .....
Was just about to set about removing the sump from my Dads A4 Avant 2.0Tdi Quattro to inspect the oil pump drive shaft but on reading the Haynes manual it states that that if you have a 6 speed box then the engine needs to be removed from the car and the flywheel taken off .. Is this true ?? surely you dont have to remove the engine to get the sump off that's madness ?
