Volks AutosJMB Retrofits
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By ruairi83
Thread: HID's and bumper removal
    May 2012
    Kings Lynn
    896
    Got my HID's throuigh today. Any B7 ownerws with HID's please advise whether they had to remove their bumper to fit them and also, where did you place your ballasts for best airflow etc?
    Thanks, Lewis
    Current - 2006 B7 A4 S Line Saloon 2.0T TFSI Special Edition, Unicorn stage 1 remap, Metallic Dolphin Grey, 18" TTRS Rotors, Ferrari Red front/rear Calipers, 3.5" Powerflow tailpipes, BOSE, Cupra R splitter, Chrome grille slats, S4 Mirror covers, Black/silver leather interior, Debadged, Arm rest delete, LED plate lights, Dectane LED Red/Crystal tail lights, HID 6k, RS 4 pedals, Rev D D/V, APR snub mount, NGK 7s
    Gone - 2005 B7 A4 Avant 2.0 TDI
    ruairi83's Avatar
    Dec 2007
    739
    You need a very lon torx bit and you don't need to remove bumper I just undid the lights and moved forward lights and fitted my kit mate
    Av4nt likes this.
    ruairi83's Avatar
    Dec 2007
    739
    Two nuts at top and one on each side
    Deep down of light you will need small torch and as said long torx screw driver
    Dec 2012
    Birmingham
    295
    Visit SinghB7's Instagram Channel
    I'd take the bumper off and do it, so much space to hide the ballasts behind.
    3 x torx under the bonnet, top of grille
    3 x underneath to seperate from undertray
    Now for the last 4, you have to undo the arch liner and push it out tge way. You will see 2 more torx and remove them. Then you will see 2 x 10mm nuts, ideally need long extension with 10mm socket. The. Just pull the bumper away from the car.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,480
    bumper off is the best way
    but if you cant be arsed to remove the bumper.
    it can be done very tight tho and not many options to put the ballast.
    ruairi83's Avatar
    Dec 2007
    739
    I honestly didn't think it was so tight doing it without bumper of and took at most 30mins taking my time.
    May 2012
    Kings Lynn
    896
    ill have to have a look and see whats best for my car then. cheers peeps
    May 2012
    Kings Lynn
    896
    Somewhere mentioned about changing fuses in regards to HID's and voltage etc etc... is this not necessary because the ballasts sort that out?
    ruairi83's Avatar
    Dec 2007
    739
    As long as your kit is a canbus kit for your car there is no need to change fuses.
  1. A3 Front Bumper Removal
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2011, 08:00
  2. bumper and mirror removal
    By mattyboyc in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th March 2010, 00:39
  3. rear bumper removal
    By RichA3Turbo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st October 2004, 21:31
  4. Bumper removal
    By jay3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2004, 16:56
  5. Rear Bumper Removal
    By Jon in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2003, 13:10
