Got my HID's throuigh today. Any B7 ownerws with HID's please advise whether they had to remove their bumper to fit them and also, where did you place your ballasts for best airflow etc?
I'd take the bumper off and do it, so much space to hide the ballasts behind.
3 x torx under the bonnet, top of grille
3 x underneath to seperate from undertray
Now for the last 4, you have to undo the arch liner and push it out tge way. You will see 2 more torx and remove them. Then you will see 2 x 10mm nuts, ideally need long extension with 10mm socket. The. Just pull the bumper away from the car.
