JMB RetrofitsBadger5
Results 1 to 28 of 28
Like Tree3Likes
  • 2 Post By bez101
  • 1 Post By Lion Heart
Thread: Definitive Answer: Where to Place Axle Stands B7 S4
    Apr 2011
    77
    Hi guys
    This one's proven quite frustrating...
    I've done several Google searches and nobody seems to offer a definitive solution as to where the axle stands should be placed.
    Description with an image would be ideal!
    Do Audi main dealers have an 'official' axle stand point, or do they never have use of axle stands due to having various ramps?
    WOuld be really useful to lock this down for people, like me, who are searching for a clear and concide answer.
    Any help much appreciated!
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    under the car ?
    kanecullen89 and DriverN00B like this.
    bez101's Avatar
    Jul 2008
    8,492
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    476
    Under the wishbones/subframe or I have little blocks of mahogany cut that fit in the top of my axle stands with a slot for the sill. Pretty much any where you'd jack it from, Google jacking points.
    bez101's Avatar
    Jul 2008
    8,492
    the stands i have have rubber blocks.
    i stick them under the sills where the caps are
    Mar 2013
    Berkshire
    398
    This may be of some use
    For a 2003 - 2008 Audi S4
    Apr 2011
    77
    When you say sills I assume you mean the standard jacking points (shown in the image)?
    I find it really hard to jack it up and have enough space to then put an axle stand next to the jack to lower it back down on to.
    Any images of the points for the wishboes or subframe??
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    637
    I don't have pics of the subframe, but basically as the above comment put the stand where the bolt goes through the subframe onto the body.
    Apr 2011
    77
    Front and rear??
    Any images guys?
    Apr 2011
    77
    Come on guys - anyone got any images???
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    476
    Don't think many people would take pictures of where to put an axle stand when doing work tbh mate. If you're not really sure and can't work out how to support your car are you sure it's something you should be doing yourself? Truth is there is no definitive answer, depends what your doing, height car needs to be at, type of head on the jack and stands etc, I usually just work it out as I go.
    Apr 2011
    77
    It seems this is a common question when doing a Google search, but nobody has provided a firm answer.
    Many people say where the suspension arm meets the chassis.
    I thought it would be useful for people to find out an answer from those who have done it, and images say a thousand words.
    I've put cars on axle stands before, just not an S4.
    Khanage likes this.
    Feb 2013
    Wiltshire
    346
    Putting them on the subframe bolts will be fine.
    Apr 2011
    77
    Can anyone here try Google to get some images together? You don't have to take your own as appreciate that's a hassle, but would be really useful for forum users to get a solid answer on this.
    Thanks guys!
    bez101's Avatar
    Jul 2008
    8,492
    cant you google yourself ?
    plus the image above is where the stands go
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Like Bez says, if you think this would be useful information for the forum, why not establish it yourself, and then share it with the forum?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Apr 2011
    77
    Ok then. I'll work it out myself.
    Thanks for that.
    bez101's Avatar
    Jul 2008
    8,492
    its been worked out for you in post 6
    i dont see a problem the question you asked has been answered with a very good image
    including 3 diffrent methods of raising the car
    1 jack
    2 stands
    3 2 post lift
    all useing the oem jacking points.
    Apr 2011
    77
    Yes, but if you read any posts on the net about this subject most mention, quite rightly, that there's not enough room in the sill jacking points for both a jack and an axle stand.
    Additionally, people have mentioned using various sub frame and suspension points - which I feel is the correct answer, but are not the 'official' points shown in the image above.
    So no, it's not quite that straight forward I'm afriad.
    But if I'm really the only person who needs an answer to this (seemingly) quite common question then not to worry I'll work it out.
    Feb 2013
    Wiltshire
    346
    I'll get my car on a lift tomorrow if I can and will get some pics for you. Subframe mounts are best in general due to their inherent strength. They are holding the car up anyway.
    Apr 2011
    77
    ricostuart
    You are a gent and a star! Look forward to seeing those - and I'm sure they'll be useful for many people for a few years to come as seems to be a fairly regular question on the various forums!
    Feb 2013
    Wiltshire
    346
    Shop a little busy so can't get the Audi on the ramp today so will get some stock photo this evening for you.
    Big Al's Avatar
    Engine knackered!!
    May 2011
    West Midlands
    302
    Here's my car on a post lift ramp, supported from the sills using rubber inserts on the ramp arms to stop the pinch welds being crushed.
    You can use a V cut piece of wood on the top of each axle stand to protect your sills OR you could invest in ECS RS4 sill protectors which fit over the sills? This is the best solution, which I'm considering buying myself.
    Here's a link to the ECS website -Audi B7 S4 V8 ECS News RS4 Jack Pad Kit for your B6/B7 A4/S4 plus the parts page itself Audi B7 S4 V8 Search SiteSearch RS4 Jack Pad Kit - 8E0801789KT2 - RS4 Jack Pad Kit - ES#2598405
    If you use a jack like this you'll be able to fit an axle stand other end of the car on the other jack pad? Or you could use drive on ramps instead?
    Alistair
    Audi A4 B7 2004 red 2.0 TFSI Quattro Sport saloon, Servotronic steering, MFSW, CDIS, DRL with Coming Home, auto dual xenon lights/wipers/mirrors, split folding rear seats, 3rd headrest, centre armrest, Isofix mounts, RS4 rear ARB, pedals & carbon dash trims; Audi TTS 9Jx18alloys (2 sets), Yokohama AD08 summer, Conti TS830P winter 245/40/18 tyres, TPI 15/20 spacers/lockers, Pipercross filter, GFB DV+ turbo valve, NGK BKR7EIX plugs, Osram Silverstar Xenarc D1S bulbs. Build thread
    Feb 2013
    Wiltshire
    346
    You can use these points:
    The rear wheel suspension arm
    The front:
    You can see the bolt bush that the front suspension connects to the chassis.
    They ain't the best places as the sills are better, but they will certainly work fine. Use these with the 2 post lift with no issues.
    Big Al's Avatar
    Engine knackered!!
    May 2011
    West Midlands
    302
    Here's a picture from another thread by Andy TQ who had an exhaust fitted. You can see the front suspension lower support brackets quite clearly.
    T3nnant's Avatar
    Jan 2013
    Newcastle
    363
    I cant remember the name of the item or which post it was on... but someone did post about a type of jack and axle stand combo which worked together. it was an American company. In which the axle stand has a cutout so it fits around the jack and lifts/secures it from the same spot. very clever idea!
  28. #27
    Liquidfusion's Avatar
    Sep 2011
    London
    361
    Not sure if this helps but this seems like a good place to put them?
    Jacks, jack stands, where do I put them? --> jack pointers inside. - AudiWorld Forums
    2013 Audi A4 1.8 TFSI 170 S line - Daytona Grey. 19" Black Edition Alloys. MMI 3G Navigation Plus, Bluetooth Phone and Voice Prep,
    Heated Seats, Cruise Control, Eibach Sportline Suspension, Tinted Windows Factory Shade,
    Ice White Fog Lights, Interior LEDs, Mobius Dash Cam, Red Calipers with S Line Decals
    S Line Grill Badge. Remap Stage 1 (Pending)
  29. #28
    Feb 2013
    Wiltshire
    346
    This is where I use the 2 post lift on the s4
    But if I had longer arms I would put it here on the front
  1. Safest places to position 4 axle stands on s3?
    By Az in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2012, 22:31
  2. Axle stands - Where do I put them?
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2011, 00:01
  3. Jacking & Axle stands
    By jvbates in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th July 2009, 22:29
  4. Trolley Jacks and Axle Stands
    By Tallpaul in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2006, 16:58
  5. Where to place jack stands(rear)
    By Mutinyno9 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th May 2004, 19:24
