    Apr 2011
    77
    Correct Way to Remove S4 Caliper Spring Clips (without damaging brake pad bracket!)?
    Hi guys
    On the front calipers on the B7 S4...
    The last time I removed them I managed to snap off both of the brackets which attach to the rear of the outer brake pads :o(
    Now, about to do it again and wondered what the correct proceedure is to get these off easily?
    What I did last time (incorrect it seems!) was to pry out the two ends of the clips and then the centre just sprang out (with the brake pad brackets - oops!)
    From memory, the rears don't have the spring clips???
    Any advice appreciated! (I want to do it right this time!)
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    I don't believe there is a set procedure for this. I was just extra careful when removing/fitting to be honest. I'll have a look on ELSAWIN when I get a chance and see if there is anything mentioned in there.
    Azeem
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    Apr 2011
    77
    Ok great! I'm thinking it's probably correct to remove it from the centre - but unsure which way to press it in to get it out.
  1. Replies: 11
    Last Post: 6th February 2013, 12:11
  2. Easiest Way to Unclip Air intake spring clip...
    By _G_ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th May 2012, 09:55
  3. what is the best way to remove.LONG CALIPER BOLTS ON THE REAR OF AN AVANT??
    By cominatcha in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th March 2012, 01:34
  4. Best way to remove stuck on number plates?
    By A3_TOBES in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th August 2006, 19:16
  5. Learn your ABC the correct way!!!!!
    By necroeire in forum General Chat
    Last Post: 13th May 2005, 09:40
