Hi Guys
I have a 2006 Audi S4 Avant.
I'm in the UK, so drivers side being the right hand side of the car for me.
Basically the drivers door is misaligned and is rubbing against the wing when opened, which has caused a rust patch which I will get repsrayed once this issue is sorted...
Upon further investigation it's not just the top edge of the door which is mis-aligned (I originally assumed it had dropped hence rubbing on the bottom edge), rather it is misaligned on both the top and bottom.
The gap between the wing and door edge is tiny all the way down the edge, and the gap between the other edge of the door where the two doors meet is rather big.
So the whole door needs shifting 'backwards' by a good few mm on both the top and bottom.
Is this possible, and if so how's it done???
Much appreciated!
Much appreciated!
