Sky InsuranceAH Fabrications
Results 1 to 15 of 15
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    340
    2009 A4 - Does it have SD card slots?
    Hi.
    I currently own an A3 and am shortly looking to buy a 3.0 TDI A4 approx 2009 or 2010 model.
    I'm after one with the sat nav system built in.
    Does this system have SD card slots so I can play my MP3s such as the A3 RNSE?
    I've looked on some photos but can't see the slots.
    Chris
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,675
    An A4 fitted with RNS-E will have SD card slots. They are concealed behind the screen, which drops down when you press a button on the head unit fascia. It will take SD cards (the manual says max 2gb but you might find it will accept 4gb) but not SDHC cards.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    340
    Quote Originally Posted by jdp1962 View Post
    Apologies i've put this in the wrong section - should be in the B8 forum.
    The sat nav I was meaning was the screen at the top of the dash and controls near the gear shift.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,675
    Quote Originally Posted by Djwoody View Post
    In which case, you'd better ignore everything I said.
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    340
    Haha. Could a moderator move this to the B8 forum please?
    2008 Audi A4 B8 3.0TDI Quattro S-line (240) in Aruba Blue
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,675
    I'm sure they will. It just might be later today.
    27,073
    Depends on the system fitted, any pics of the actual dash?
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    340
    Something similar to this
    27,073
    MMI.
    Jan 2012
    1,837
    2G won't, 3G will.
    If thats the pic of the car then it looks like 2G so it won't have them fitted.
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    340
    Quote Originally Posted by a6-chris View Post
    2G won't, 3G will.
    That's not the actual car I'm after, just would like to know for when I find one.
    How can I tell the difference between 2G and 3G by looking at the dash?
    Jan 2012
    1,837
    2G has the Cd changer on the dash as per that pic, 3G cars will have a drive there called 'Audi Multimedia'.
    If no MMI is fitted you'll have no entertainment controls around the gearstick and you'll either have Chorus/Concert/Symphony on the dash.
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    340
    Lovely. Cheers
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    MMI.
    So posted in the wrong forum as it must be a B8 if it's got MMI.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,675
    Quote Originally Posted by PetrolDave View Post
    Yup; OP realised that a while back and asked for the thread to be moved. No one has moved it yet.
