Badger5EM Tuning
Results 1 to 12 of 12
    Jul 2013
    74
    Help changing wiper blades
    I have had a look through the topic nothing yet has helped. I have tried pulling and pushing with a hectic of a lot of force.
    It just feels uncomfortable and that something that shouldn't is going to give way.
    I have no clue how to get them off , YouTube has been fruitless too.
    Here's a picture if my blade , if I'm missing something obvious please put then dunce cap on me and tell me.
    Jan 2014
    Gatwick
    47
    Just type ' how to remove wiper blade a4 b7 ' in Google
    Molnboman's Avatar
    Am a mechanical numpty Mate.....and if I can do it anyone can.....Firstly....Might want to make sure you protect your windscreen from the wiper arm smacking your windscreen by placing cardboard or a towel on the screen.. A wee squirt of release spray into the gap of the plastic arm bit might help too. It will probably be stuck together with road muck and salt...Just hold the main plastic bit and pull it the opposite way / away from the wiper arm.....Putting the new ones on...depending on type, if it's Valeo / VAG they do have seperate blades for driver and passenger side.
    Good Luck
    A
    Jul 2013
    74
    No joy another day of struggling !!
    Tried the above , no joy they appear wielded on !
    I've taken a few more pics
    Totally baffled ! Never thought wiper blades would defeat me.
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    728
    Strange, the plastic should just slide open with some light assistance. Have you tried placing a flathead screwdriver between the metal and plastic?
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    Molnboman's Avatar
    Jaysus, what are they doing to you Mate! There's only the a metal male tongue part holding the blade part onto the arm itself, between the wiper arm and the smaller wedge section. You could try moving that part with something safe, to free it up a bit. Don't end up doing a Basil on your car....https://www.youtube.com/watch?v=78b67l_yxUc
    Keep the Faith,
    A
    rizzini7's Avatar
    Jun 2011
    728
    Sep 2013
    63
    looks like corrosion as i had one side that was a nightmare to remove as the inside was corroded.
    I found it easier to kinda squeeze side while using my nail to catch the clip to push off while pulling and squeezing though and keep working the whole side from left to right but i mostly went to the top to edge it off. As mentioned above try using a screwdriver, could use some wd40 if you place a towel on the screen under wiper to catch residue, then clean the crap of before install the new wiper.
    rizzini7's Avatar
    Jun 2011
    728
    Good luck mate, just watch you're windscreen and you're hands if using the screwdriver. Luckily mine came off fine. But putting the new ones on was another story.
    Oct 2012
    Midlothian
    251
    I feel your pain, I couldn't believe how difficult it was to get them off, brut force won eventually but I did feel as if something was going to break. Not the best design imho.
    Craig Cull's Avatar
    Oct 2011
    Leeds uk
    1,139
    Visit Craig Cull's Youtube Channel
    Spray some wd40 into gap, it will move eventually, you'll just find it's corroded inside.
    K04 hybrid turbo. S3 injectors, Autotech hpfp internals, RS4 fuel pressure regulator, custom FMIC, APR carbonio intake, decat pipe, milltek cat back non resonated 100mm tips, unicorn developments custom remap, launch control and flat shift. Valet mode, economy map and full power map options. Stage 3 southbend clutch with single mass flywheel, Eibach pro street coilovers, eibach front and rear anti roll bars, porsche cayenne 6 pot calipers front, S4 rear brake conversion.
    i_786_i's Avatar
    Aug 2012
    57
    Stick a flat screwdriver between the cover and end of wiper, then simply twist... the cover should pop off
  1. Changing Wiper Blades
    By Danny-boy in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th March 2013, 19:47
  2. Help, replacing front wiper blades on A4 avant 2003
    By beckytm in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th June 2012, 11:00
  3. Avant rear wiper blade change
    By sidibear in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd December 2011, 16:49
  4. Replies: 2
    Last Post: 18th January 2010, 20:41
  5. Wiper Blades - have they changed part number?
    By geordiea3 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 25th November 2009, 23:38
