EM TuningJMB Retrofits
    Sep 2008
    Nuneaton, Mids
    237
    Power steering fluid leaking from drivers side gaiter. Blown seal ?
    Yesterday whilst out shopping I noticed my steering beginning to squeal/grind and it got progressively worse over a short amount of time.
    Checked my fluid level and it was just touching the end of the dip stick, so I added some generic power steering fluid, tuned from lock to lock a number of times and all was well and managed to get home with no issues.
    Started the car later that afternoon and turned the wheel and the squealing was back and I also noticed brown fluid on the drive, I opened the fluid reservoir and was greeted by a brown foamy mess.
    Upon on further inspection (after cleaning the mess behind the drivers wheel and all down the side of my car !!) I have power steering fluid leaking from the end of the tie rod gaiter.
    I have bought 2 bottles of fluid so I can get the car somewhere for repair but I have a feeling it will be an expensive one !!!
    Does this indicate a blown seal ? Is there any way of getting this fixed without replacing the entire rack ?
    Any help would be much appreciated as I'm sure I can't fill the reservoir before every journey !
    Thanks in advance
    North East
    607
    Quote Originally Posted by unitzero View Post
    Thanks in advance
    Sounds like a blown rack ?
    Racks can be refurbished but the repair is usually short lived in my experience.
    A new rack including fitting will be of the order of £800- 1000, may be more , YIKES !
    Sep 2008
    Nuneaton, Mids
    237
    I have seen reconditioned racks on eBay for like £150/£200 with 2 years warranty but if they don't last and presumably don't cover labour charges to remove and replace under warranty then it could be a non- starter.
    I've been told to look behind the gaiter and to inspect the input shaft and servo's but I honestly don't have the time or space to do this.
    I have a number for a local power steering specialist so will call them tomorrow and see what they suggest.
    Sep 2008
    Nuneaton, Mids
    237
    I did take some pics after cleaning all the mess today ...
    The boot is full of fluid, I can squeeze it and it leaks out by the clip. I got the wife to turn the wheel and got squirted in the face !
    It seems that the only way fluid can get into this boot is via a blown seal where the shaft enters the rack.
  1. Power steering leak?
    By smoking_bob in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st February 2012, 16:25
  2. Rotational Rattling Noise From Drivers Side Front Wheel...Please help!
    By Nickpap in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2010, 21:04
  3. Power steering Leak.
    By V.I.P_UAE in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2009, 15:19
  4. strange whirring noise coming from drivers side front wheel
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th March 2007, 23:37
  5. Water Leak on Drivers Side
    By S3DBW in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2004, 07:20
