Badger5JMB Retrofits
Thread: Window help
    Nov 2013
    30
    Window help
    Hi guys bit of a problem my drivers side window has gone down but I can't get it back up ? Any ides on how to manually get it back up without breaking anything I've orderd a new switch as it's the one I have at the moment that I think is faulty, just I can't use the car if the window is stuck down any help much appreciated
    Jun 2012
    Aberfeldy,Scotland or Antrim, NI
    147
    This could be broken wiring in the door loom mate. Common problem.
    2002 Nogaro Blue 8L Facelift S3
    WTB. Concert CD player unscratched (8L0035186G)
    Heater control unit unscratched (8L0820043H)
    Headlight switch. (
    Nov 2013
    30
    Jeez I hope I'm hoping it is just the switch nice easy fix, fuses ok and relays are ok so next port of call is the switch I think fingers crossed, just need to get the window up then al be ok
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    726
    You got window roll up on the key remote mate?
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,480
    do the other wivdoes work ?
    does the locking and mirrors work ?
    if yes its not the loom
    as above press and hold lock for a few seconds it should roll the window up
    if it doesnt its the motor
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    551
    Add GeoffDunk on Facebook
    Quote Originally Posted by chris199 View Post
    Hi guys bit of a problem my drivers side window has gone down but I can't get it back up ? Any ides on how to manually get it back up without breaking anything I've ordered a new switch as it's the one I have at the moment that I think is faulty, just I can't use the car if the window is stuck down any help much appreciated
    Chris, when you say its gone down, did it go down silently and using the electric motor or did it get stuck a little and grind etc. When trying to get it back up does it make any noises etc?
    I only ask because there is a common problem on both Audi's and VW's regarding the window regulator mechanism. its a common fail and pretty reasonable to fix. I am sure there is a how too on here but it does mean stripping the door and fitting a new mechanism.
    I just wanted to get clarification, it may be an electrical fault as you 1st thought.
    Audi S4 quattro in Dolphin Grey Metallic, Silver leather, carbon inlays, RNS-E, 6 speed manual, electrically adjustable & heated seats, xenon headlights with power wash, cruise control, storage pack, 18" OEM RS4 wheels, RS4 ARB, LED lighting upgrade, FASH plus every bill since new.
  1. passenger side windows...help!
    By tommac in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th March 2010, 13:57
  2. electric windows help
    By mrjheeta in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd December 2008, 08:25
  3. Window help
    By OllyS4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th March 2008, 14:02
  4. Windows help needed
    By MikeS4 in forum General Chat
    Last Post: 7th November 2007, 12:08
  5. closing of drivers window (help)
    By Vikz in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th August 2006, 23:53
