Hey bez101, new to thus site. I heard there r 4 censors? How much will it cost to fix them? I just replaced my clutch and now my wheel bearing. So the cheaper the better. Thank you for your quick response
And welcome to the forum. Usually its best to state a small description on what sort of vehicle you have. Obviously its a Audi A4 B7 shape otherwise you would be in a different section.
well your in the wrong section you need to be in the B5 section
you are right you have 4 sensors do you know what one is ****ed ?
have you had the fault codes read by vcds ?
cant really help you with prices as im in the UK so wont be the same in the us
the fault code means nothing to me if you can get it on VCDS vag com and post the code then i could help out with witch sensor has gone down
