JMB RetrofitsBadger5
Thread: Dreaded dpf
    Mar 2014
    Dreaded dpf
    Alright folks. Got a 2007 a4 2.0tdi, engine code BRD r4. Got Dtc 008194 (particulate trap bank1) p2002 - 006 efficiency below threshold. Have followed Ross tech wiki to manually regenerate car. Soot was up at 130ish and managed to get it to 20%. Can't get it any lower. Could anyone tell me how to get it to force regen through vcds? I don't have the security/access key for it. Think that's all that's holding me back. Thanks in advance.
    Nov 2013
    Heath Hayes
    951
    Is it not the first part of this document that describes how to regen it.
    Diesel Particle Filter Emergency Regeneration - Ross-Tech Wiki
    How many miles has the car done?. It's not always possible to get it down to zero as there is usually a build up of ash that cant be burnt off. especially if there has been an issue with the car or it has not regenerated for a long time. Unfortunately DPF's don't last forever.
    Karl.
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    Mar 2014
    It was the top part I followed and could only get it to 40% but then when I go to retry it's at 20ish% until I start and it goes back up. The dtc will erase but appears straight away. I was told the lights won't reset until soot mass is under 10% that's why I wanted to do a forced regen by vcds. I work with nissan and you just hit the regen button for that,nice and simple. I tried to trick ecu into thinking dpf was replaced but the value is already at 0. I thought if done a forced regen and it still failed I'd replace the g450 sensor but since there is no dtc for it,that was last resort.
    Mar 2014
    Or is the forced regen done through the manual depending there the 1 sits on the measuring block? Just re read the wiki link
    Mar 2014
    Sorry forgot to say it's at 118k. A friend wanted me to try sort it. I'm still b6 20vT,much less hassle,haha.
  1. The dreaded DPF
    By talisman71 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th September 2013, 11:34
  2. New Audi owner, couple of questions and the dreaded DPF topic, if you please
    By audiruss in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th August 2013, 23:54
  3. Oh no the dreaded immobiliser thread!!!!
    By madkebab in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th January 2006, 16:48
  4. Dreaded electrical problems!
    By Vorshprungdork in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2005, 20:34
  5. Audi A3/Sportback 2.0 TDi (DPF)
    By dorgan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th June 2005, 22:01
