JMB RetrofitsSky Insurance
    May 2013
    33
    audi a4 intake manifold flap motor fuse ???
    Hi All,
    Does anyone know the location of the above fuse as I can't find it and I have a fault showing. I have taken the EGR and this manifold motor off and cleaned them both (they were not bad) but I think the motor is not getting any power so I want to check the fuse but can't see any reference to it.
    Cheers Rick......
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Need some more information about the engine/issue buddy.
    I don't think the motor will have it's own separate fuse as such and is simply supplied by the engine control module.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    May 2013
    33
    Quote Originally Posted by A4_MaJiK View Post
    The code I got from a cheap audi scanner was 012546 and this is what ross-tec says. The highlighted comments are what I'm going to do or have done already.
    19558/P3102/012546 - Motor for Intake Manifold Flap (V157): No Signal Possible Symptoms
    • Hard Shudder when turning OFF the Engine
    Possible Causes
    • Fuse(s) faulty I want to find and check the fuse if poss
    • Wiring and/or Connector(s) from/to Intake Manifold Flap Motor (V157) faulty I will check for a voltage tonight
    • Intake Manifold Flap Motor (V157) faulty I have removed and checked and cleaned
    Possible Solutions
    • Check Fuse(s)
    • Check Wiring and/or Connector(s) from/to Intake Manifold Flap Motor (V157)
    • Check/Replace Intake Manifold Flap Motor (V157)
      • Perform Output Test I need to do this now I have a vagcom unit
    Mar 2013
    Oxford
    38
    is your car a diesel?
    i have worked on a few diesel golfs with the same fault which turned out to be a fuse,i think from memory the fuse was marked as being for the cooling fan,no mention of the intake manifold flap but when fuse was replaced the v157 fault would clear.
    May 2013
    33
    Quote Originally Posted by laruk View Post
    Cheers laruk
    It is a diesel and I have been researching this and I've seen that the cooling fan fuse is mentioned so I will be having a look tomorrow if I get a chance.
  1. Replies: 191
    Last Post: 4 Hours Ago, 10:07
  2. Audi A4 Avant 2.0 TDI 170 - injectors, EGR and Intake Manifold Flap
    By agedog in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th March 2012, 20:46
  3. Problem with: motor for intake manifold flap malfunction 19559 v157
    By kaos in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th December 2011, 14:59
  4. Help - Part Number for Motor Intake Manifold Flap - EGR Valve
    By miszka20 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd July 2011, 20:02
  5. *fault* Motor for Intake Manifold Flap
    By a3guy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th November 2007, 12:54
