AH FabricationsVolks Autos
Thread: Is this normal
    Feb 2014
    Is this normal
    Hi guys,
    Recently purchased a Audi 2007 A4 2.0tfsi S-line SE which currently has 56000 miles on the clock. After reading a few common faults, I decided to change the following as a precautionary measure.
    -HPFP cam follower
    -PCV valve along with the smaller of the 2 hoses
    -DV to be replaced soon
    Car runs perfectly normal,idle is smooth and is where it should be, I get around 350-400 miles to a tank of fuel which I think is about right. No fault codes.
    My concern is when I removed the oil filler cap today there was a slight hissing sound and the idle went rough, is this normal.
    There is no oil around the filler cap. The oil filler cap was not difficult to remove.
    Many Thanks
    Sheldon
    Molnboman's Avatar
    Quote Originally Posted by SwickS View Post
    Hi guys,
    -HPFP cam follower
    Many Thanks
    Sheldon
    Hej Sheldon
    Welcome to the Forum. Don't get in a habit of doing that too often, but from what I understand that is normal. If your filler cap is easy to remove when at idle that means your PCV is fine. Sounds like your on top of things with changing the main dodgy items. I am presuming that your water temp is bang on 90c.....,if not your thermostat needs replacing...but you wouldn't be getting good mileage otherwise.
    BR
    A
    Feb 2014
    Phew thought I was in for a rogering.
    Temp is bang on 90c
    Thanks for the info, much appreciated.
    Sheldon
  1. my a6 keeps locking itself is this normal?
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th October 2006, 19:38
  2. My dash lights seem permanently on - is this normal?
    By rgb8888 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th January 2006, 12:24
  3. headlights are apaulling, is this normal
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th January 2006, 22:52
  4. Picked up S4 - is this normal?
    By imported_SunDiver in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th February 2005, 00:11
  5. Sound on acceleration - is this normal?
    By imported_bantam1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th August 2004, 22:48
