Badger5JMB Retrofits
Results 1 to 9 of 9
    Feb 2014
    Christchurch, Dorset
    22
    Ignition key - excessive battery drain
    One of my keys has normal battery life but the spare discharges a battery completely flat in less than a week even if it isn't used. This means I have to keep a supply of new batteries handy 'just in case'.
    Has anyone else come across this problem and if so, is there a simple fix?
    I'd appreciate advice.
    58 plate A4 2.0Tfsi S-line SE Cabriolet in Misano Red with retrofitted cruise control and Westfalia removable towbar and dedicated electrics.
    Jun 2012
    Aberfeldy,Scotland or Antrim, NI
    147
    Are you sure they are actually dead? My S3 spare key used to do this but once I'd unlocked the car manually and started the car with it it worked fine.
    2002 Nogaro Blue 8L Facelift S3
    WTB. Concert CD player unscratched (8L0035186G)
    Heater control unit unscratched (8L0820043H)
    Headlight switch. (
    Feb 2014
    22
    Quote Originally Posted by Arnie013 View Post
    Yes. I have a battery condition tester that shows the batteries to be completely discharged after a few days.
    If I fit a new battery and synchronise the key to the car again, it works fine - but not for long. It's very frustrating.
    Jun 2012
    147
    Now that is strange! Can't help then I'm afraid buddy.
    Headlight switch. (
    Feb 2014
    22
    Thanks for your interest.
    May 2012
    RETFORD, NOTTS
    1,753
    What's the remote part number i could supply a new remote?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,536
    Quote Originally Posted by Marklar View Post
    Sounds like a faulty remote - it hasn't got wet at any stage (like being dropped in the sink or accidentally washed while in a trouser pocket)?
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Feb 2014
    22
    Quote Originally Posted by PetrolDave View Post
    No, Dave. It was like that whan I bought the car second hand but I didn't notice the fault until a few months later when I tried to use the spare and it was completely dead. I fitted a new battery, resychronised the key and when I tried to use it again a week later, the battery was dead. It happens every time I replace the battery.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,536
    I would say it's definitely a faulty remote, don't bother wasting any more batteries on it - bin it and get another one.
  1. Ignition key switch sticky!!!!
    By Daz A3 TDI 130 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2008, 18:20
  2. ignition key problem
    By audi doodey in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th December 2007, 17:59
  3. coupe battery drain
    By andy64 in forum Classic Audi Forum
    Last Post: 13th February 2006, 12:43
  4. key pad batteries
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2005, 19:21
  5. Battery drains out in a day.
    By mashoud in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th November 2004, 07:36
