Volks AutosSky Insurance
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    235
    Heated seat problem
    Does anyone know where the relay is located for the heated seats and what relay it is.
    mine won't heat now, and I've checked the 35A fuse in the side panel fuse box which is fine, so I can only presume its a relay issue as both seats won't work.
    if anyone has other ideas please feel free to express
    Oct 2013
    266
    Might be worth trying a request for a wiring diagram as you may find theres no relay at all, it could be all run from the bcm or whatever audi call theres?
    The 35a fuse may cover the power side, but what about the trigger side, ie the power signal from the switch to the bcm/relay etc?
    Have to say 35amp is a bloody big fuse for heated seats, thing the ones in my old landy are 10 amp. for both seats.
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    235
    The seats are turned on from the heating control panel via rollers (potentiometers)
    The strange thing is both seats have stopped working and the passenger seat is rarely used!!!
  1. Possible heated seat problems...
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2013, 10:26
  2. New User! Help! Heated Seat problem!
    By dsellick in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2013, 09:58
  3. Audi a4 heated seat problem.......long post Helppppp
    By Craig1989 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 29th December 2011, 16:04
  4. Heated seats problem - Stays on!!
    By Blueie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th February 2011, 12:01
  5. Stereo, heated seats, tempreture sensor problems on my tdi cab
    By dhillon884 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd February 2010, 10:10
