Chris NottJMB Retrofits
    Feb 2014
    Windscreen demister motor
    Hey guys
    been looking at buying a a4 2.0 tfsi 2005 off a friend of mine. Trouble is none of the motors that control the airflow to upper ,middle and footwell vents appear to work. The green lever one( windscreen demister moves a little but not much) Have tried all combos on the controls. A mechanic friend of mine has said the problem may be the body control module. Does this sound about right and how much would it be to fix approx.
    Many thanks
    kite's Avatar
    Oct 2007
    East Berks
    675
    Take the motor out. Take them apart grease the worm drive gears. Put back together. Put them back in and reset with badic settings with VCDS.
    Then see if they work.
    A4 (b6) 2.5 TDi QS Saloon.
    Feb 2014
    Ta for the quick reply. Have already taken green levered one apart and done that. Only get small movement on it . Almost like motor I sent strong enough to move it thru its full range. Nothing from other two motors. In fact selecting footwell vents caused a little movement in the demister( green) lever!!!!!. This was why friend suggested body control module.
    Also what is badic and VCDS
    Martin
    kite's Avatar
    Oct 2007
    East Berks
    675
    Typo. Basic settings.
    VCDS= vagcom diagnostic system.
  1. HELP! windscreen demister
    By blackwood in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th January 2014, 13:30
  2. windscreen demist problem
    By teknik in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th October 2011, 08:23
  3. Windscreen demister problem
    By cocain in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th November 2010, 16:58
  4. Windscreen demist not working
    By eds in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th December 2009, 14:10
  5. Windscreen wiper motors....
    By in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2005, 10:02
