Volks AutosChris Nott
Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By Pat.
  • 1 Post By Pat.
Thread: Hunter Wheel Alignment
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,683
    After getting new tyres put on last Friday, and seeing the additional wear on the inner shoulders of the old ones. I got a four-wheel alignment check done today. The nearest Hunter-equipped place is a BMW motorsport specialist about half a mile from the house. I took it in first thing this morning, and they did it on the spot; it took about an hour and a half. I've got a before and after printout; there was quite a lot in the red zone before, mostly front and rear toe.
    Now, everything is in the green zone, bar one exception, the left front camber. It's at -1.30 (correct setting is -1.05 with 0.23 tolerance so it's 0.02 outside maximum tolerance), but front camber is non-adjustable. Short of moving the subframe or fitting adjustable control arms, I'm stuck with it.
    Total cost £78.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    827
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Had the same sort of outcome on mine, I believe the upper control arm bushes may be worn which is causing the camber to be pushed out of tolerance. Although saying that, 0.02 is barely anything.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,683
    Quote Originally Posted by A4_MaJiK View Post
    I'm kinda thinking that way too. Let's hope we're right.
    North East
    607
    Quote Originally Posted by jdp1962 View Post
    Similar issues with my 2.0tdi.
    Wheel alignment man says its a common problem on the A4,A6 , Passats and now showing up on the A5's.
    I am just living with it as it looks a potentially expensive and time consumming issue to sort.
    Nov 2013
    Heath Hayes
    951
    On the Passat B5.5 it is possible to move the subframe to balance up the camber readings across both sides, I presume it's the same on the Audi.
    If it's on one side only and quite a bit the car may have found a kerb at some time in the winter which has knocked it out.
    1.3 degrees is not excessive and a bit of camber helps turn in. As long as the tyre wear is reasonable I wouldn't worry about it.
    Karl.
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,683
    Quote Originally Posted by desertstorm View Post
    Yeah, that's what the guy at BMSport said.
    Apr 2013
    Outer Manchester
    34
    JDP, You're on lowering springs? This'll introduce a bit of negative camber.
    As long as your toe settings are now correct and within tolerance, you should see a heck of a lot less inner shoulder wear
    jdp1962 likes this.
    /// B7 Avant 'Quartzgrau'
    flickr
    Apr 2013
    Outer Manchester
    34
    This was my 'before' printout. I'd fitted the 45mm H&R springs and B5 perches a few weeks prior..
    jdp1962 likes this.
    flickr
  1. Chemix hunter 4 wheel alignment and thanks jojo.
    By rhubarb4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2013, 10:55
  2. Hunter Hawk Eye Four Wheel Alignment at AmD Essex
    By ben@amdessex in forum Sales Questions
    Last Post: 22nd May 2012, 17:11
  3. "Hunter" 4 wheel alignment
    By Rob-Quattro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd April 2012, 21:20
  4. AMD Wheel Alignment - Had it done ? Comments please
    By imported_Smudge973 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th April 2005, 18:57
  5. wheel alignment
    By JayBeeS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th October 2003, 16:57
