My B7 S-Line 2.0T
Dwayne 1.8T
South Africa
Hi guys. My name is Dwayne. I'm from Johannesburg in South Africa. I currently own a 2006 B7 2.0T S-Line. I purchased it in Sept 2013 after previously owning a 9n3 Polo GTI...
Quite alot has been done since then. I will add all the pics I have as I go along. ..
This was the 1st time I saw her. It was traded in here at work. I work at a BMW dealer.
A pic of my Polo and the Audi...
So after taking it home, 3 days later I had trouble with it. At 3000rpm the power would just die. So to cut a long story short, I replaced the HPFP as the N276 was cracked and the piston tip was toast. The follower was also worn so it was replaced. 6.6bar fuel filter and RS4 valve was fitted... eventually the main cause was a worn cam follower lobe on the intake cam...
After the fueling issue being sorted I loaded Unitronic Stage 2 software, flashed by Yosh at Dark Artz Performance. I had the downpipe fabricated before the map was loaded. Its a custom downpipe fabricated by my mate Nishen at TMSS Motorsport.
Reactions: Furkz
Hej Dwayne
Welcome to the Forum. Quite a story you have there with your engine woes....glad they are fixed now. Might just me, but I can't seem to open those images you posted.
BR
Allan
Rides thread continued. .
Uploadfromtaptalk1393321160294
Uploadfromtaptalk1393321208228
Uploadfromtaptalk1393321257494
Absolute flawless craftsmanship!!
Shortly after doing all this the cluth started slipping with the extra power. So I pulled the gearbox quick here at work one evening and fitted a new clutch kit. ..
Uploadfromtaptalk1393321376873
Then a few more small things were done....
Uploadfromtaptalk1393321439161
New snub mount vs old rubbish
Uploadfromtaptalk1393321483600
Joey mod the headlights
Uploadfromtaptalk1393321539946
Blacked out grille
Uploadfromtaptalk1393321618830
Eventually did a dyno run on normal pump gas, made 230whp.... very chuffed....
Uploadfromtaptalk1393321826394
Custom induction that I made and painted tappet cover...
More pics to follow this evening... loads to upload...
Hej Dwayne
BR
Allan
Thanx Allan... uploading these pics through tapatalk... will try upload them again. .. stupid net work lol
So I decided to respray my mag wheel center caps, as they were peeling badly... changed the chrome bits too
Uploadfromtaptalk1393327192885
Heatsoak has been a problem for me and the twin cooler setup was just not cutting it. I had my fmic from my polo (550x180x65) so I decided to fit it in the Audi. My mate at TMSS Motorsport also did the boost piping for me...
Uploadfromtaptalk1393327391101
Uploadfromtaptalk1393327436023
Uploadfromtaptalk1393327590257
Uploadfromtaptalk1393327612679
Uploadfromtaptalk1393327640417
Uploadfromtaptalk1393327663498
Uploadfromtaptalk1393327689954
Uploadfromtaptalk1393327716235
Car feels much better now. Also adjusted the actuator a tad... its like a different car now....
that's some tasty pipe work with the new cooler :D forgot these cars have a smaller intercooler in each wing :p
the smaller coolers were not bad to be honest. But for my future plans they will not cut it :sly:
A few pics from our VW club night photoshoot...
Uploadfromtaptalk1393790464295
Uploadfromtaptalk1393790534808
Uploadfromtaptalk1393790561327
Uploadfromtaptalk1393790582910
Uploadfromtaptalk1393790617713
Still waiting for a few more oics to come from our photographer... will post them as soon as I get them...
Thanx for looking!
