jhogan
Hi, i have a problem with my maim beam when the lights are switched on it will come on after a delay and stay on for 2 seconds then switch off, if my lights are switched off i can use the flash and the main beam stays on.( can ony use main beam for flashing in daylight)
i have had someone plug in a machine and it comes up with fault code 2450 "solenoid switch for bi xenon shutter short circuit to earth", there lies another problem my car has halogen lights... they tried re coding to halogen and main beam does not work at all. I have phoned up Audi gave them my chassis number and they said it left the factory with bi xenon lights.(someone must have swapped them....don't know why)
Are the connections the same for both halogen an bi xenon? if i was to get bi xenon lights would they just fit straight in or is there a way off working round the problem and leaving the halogen lights in.
Car i have is a 2005 A4 2.0 SE TFSI quattro. any help much appreciate
