JMB RetrofitsSky Insurance
Thread: BGB or BUL
    Jan 2014
    Gatwick
    38
    BGB or BUL
    Peeps, I own May 2007 B7 Cab with a 2.0 TFSi and FWD, how can I tell if it BGB or BUL? Also, what are the differences, is one ' better ' than the other?
    Craig Cull's Avatar
    Oct 2011
    Leeds uk
    1,123
    Visit Craig Cull's Youtube Channel
    BUL is the DTM and Special Edition variant. From what I know of from a previous post literally 2 days ago, these have forged pistons. Mines running full stage 3 K04 hybrid and it loves it. As far as I'm aware the bgb doesn't have forged pistons. Good engine all in all from a BUL owner
    K04 hybrid turbo. S3 injectors, Autotech hpfp internals, RS4 fuel pressure regulator, custom FMIC, APR carbonio intake, decat pipe, milltek cat back non resonated 100mm tips, unicorn developments custom remap, launch control and flat shift. Valet mode, economy map and full power map options. Stage 3 southbend clutch with single mass flywheel, Eibach pro street coilovers, eibach front and rear anti roll bars, porsche cayenne 6 pot calipers front, S4 rear brake conversion.
    Mar 2013
    Berkshire
    387
    Quote Originally Posted by Bulbul68 View Post
    Hey just to clarify. There isnt only one 2.0tfsi engine there is few in the 200hp range on the other hand the 220 hp was only the BUL engine. The 200 hp engine codes are as follows is either BGB, BWE, BGP, BWT etc. There is a few way to tells one you can go look in your service book and there should be a a5 size sticker stuck inside the book and it will say the code there. Otherwise if you look in your spare wheel well on the right there has to be a sticker there unless again its come off through age. Last but not least you open the bonnet and have a look were the valve cover joins the head on the right hand side of the engine there is a little lip that sticks out and it will say the code there.
    Jan 2014
    Gatwick
    38
    Cheers fellows. So if the non Bul doesn't have forged pistons, how much BHP can it take? I'm thinking of a bluefin upgrade which is only 40 or so. Also, in all of your collective wisdoms, which 2.0 turbo engine is best and why?
    Craig Cull's Avatar
    Oct 2011
    Leeds uk
    1,123
    Mines going on the dyno today so I will be able to give you a figure that it will take on standard internals, but bez, Solaris and oly have seen 330bhp - 360bhp and around 360 ft/lbs of torque from the BUL engine with a k04 hybrid turbo. I would go to a reputable tuner if you want remap as apose to using a bluefin. That way you know what your getting and how it's running. Mine had a map on from what looked like something similar and it did nothing other than richen the fuel ratios, none of which Indicated any power increase at all. If you was to go stage 2 + on the standard turbo you may see around 270bhp. It's the torque figures that shoot through the roof. My mates golf gti is running 280bhp and 300 ft/lbs stage 2+ but the the k03 is pretty much on its limits.
  1. 2.0tfsi (BGB) R.I.P
    By Paranoid69 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th February 2014, 15:30
  2. Fit the new cam follower yesterday.... Snapped a pipe 2.0tfsi quattro BUL
    By Craig Cull in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd January 2013, 12:58
  3. 2.0T FSI BUL cam follower question?
    By drew306 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th December 2012, 19:59
  4. bgb head same as bwa??
    By -harry- in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th September 2012, 00:10
