JMB RetrofitsChris Nott
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By yendall24
Thread: Best oil
    imotepify's Avatar
    Feb 2014
    Suffolk
    165
    Best oil
    Hi guys, I should be picking up my new 2 me 3.2 quattro this week, its on a long life service at the mo and is only 5,000 miles into it but I have awlays done an oil change around 5,000 ish miles and would like 2 use better quality oil like Mob 1 so would you guys change the oil and filter asap or wait until the next long service is due and what oil do you guys use?
    Thanks,
    Karl.
    Mar 2007
    salford gtr manchester
    564
    I would use the quantum longlife 3 available from skoda vw and audi dealers or tps if you have an account change it every 9 to 10000 miles any sooner is a waste of money its longlife so 9 to 10000 is no problem reasonably priced and good stuff
    CHEZ likes this.
    Molnboman's Avatar
    I change mine every 10,000km's oil and filter and use re usable magnetic sump plug. I use whatever fully synth 5W 40 ( Sweden mind! ) oil my garage has on a deal. It's a very emotive debate on the Forum especially with the long life stuff which I stopped using when I took my bus off the long service intervals.
    A
    Mar 2013
    Berkshire
    396
    Considering its just the normal 3.2 I wouldn't worry too much about being on the long life stuff. If it were the 2.0T then I would stay away from long life and go to a variable service.
    For the 3.2 if I remember correct the long life is every 20000 miles/2 years which is 5w30. Some people use thicker oil to keep the noise down on the chain.
    Otherwise if you going for short changes you can go for a 5w40 but suggested to change every 10000 miles/1 year.
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    727
    Don't worry about doing long services intervals. The car will thank you for it.
    Do mine every 6k and use 5w40. Currently using comma but going to quantum next. Don't forget it holds a lot of oil .
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    imotepify's Avatar
    Feb 2014
    Suffolk
    165
    I only do around 4000 miles a year lol so normaly change oil and filter every summer with mob 1 super synthetic
    rizzini7's Avatar
    Jun 2011
    727
    Ah, not Too bad then.
    imotepify's Avatar
    Feb 2014
    Suffolk
    165
    Would you guys use Mobil 1 New Life 0W/40 Oil in the 3.2 v6? Dont want the car on long service (would rather change the oil and filter every year or 4000ish miles) Can you have the service reminder set for this, if so how?
    Thanks,
    Karl.
    imotepify's Avatar
    Feb 2014
    Suffolk
    165
    How much oil will the 3.2 hold with a filter change?
    Mar 2013
    Berkshire
    396
    I cant recall what year your car is but if its a 2006+ then its 6.5 litres.
    You should be okay with 0w40 as a alternative you can always use 5w40.
    Molnboman's Avatar
    Quote Originally Posted by Giosabcsl View Post
    Jaysus, 6.5lt.....that's quite a bit indeed!
    Mar 2013
    Berkshire
    396
    They dont call the 3.2 a tank for nothing
    imotepify's Avatar
    Feb 2014
    Suffolk
    165
    lol my Hilux takes 8.5ltrs thanks for the info guys!
    Dec 2010
    224
    Mobil 1
    Feb 2014
    Christchurch, Dorset
    22
    When I had my 2.0Tfsi serviced by our local specialist recently, he told me that they and the local Audi dealers all use Castrol Edge so that's what I bought to top up as necessary.
  1. Best oil to use?
    By markyp2002 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2006, 16:21
  2. whats the best oil for1,8t
    By mike1234 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th June 2006, 19:51
  3. What is the best oil for a A6 2.8 quattro/98
    By imported_MADEIRA in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd March 2005, 20:50
  4. Best Oil for Audi TDI
    By slips in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st December 2004, 09:31
  5. Best Oil for a 96 A4 1.8T Sport?
    By imported_bpascua in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th July 2004, 17:41
