Chris NottMonster Motorsport
    Oct 2013
    Leicestershire
    10
    HELP Alarm warning lights coming on intermittently when alarm set
    HI all
    Need some advice please?
    I have a 55 plate Audi A4 convertible 2.4 V6 TDI
    When setting the alarm on it last night around half an hour later the warning lights came on, but no siren,
    I reset this again, for it to happen again, around an hour later, thinking as it was the windy night the buffing of the wind had rocked the car I was not too concerned however this morning it has happened again,
    Beeped the alarm and half an hour later the warning lights are flashing - but alarm not going off
    Any advise would be much appreciated, before I send it in for a diagnostic check
    thanks
    Alison
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,536
    Looks like you may need the diagnostic check to see which sensor is setting the alarm off.
    Does the DIS show any door, boot, bonnet or roof open warnings?
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    the battery may have ****ed up in the siren
    you get these problems when it goes
    or as above vcds scan
    Oct 2013
    Leicestershire
    10
    Thanks for the advice.. had it or on diagnostic today. But seems to have righted itself since Thursday pm. No issues. Nothin on diagnostics now. Went round car slammed all the doors and boot shut checked Windows and reset alarm thurs night and so far ok. So assume it went into a loop when it activated due to the wind rocking the car. And has reset.
  1. Please Help! Radiator leaking! Red Coolant warning light coming on.
    By Massey127 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2013, 18:33
  2. Help - coolant warning light on S3
    By bantam1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2007, 16:17
  3. *Help* Hazard Warning lights
    By hass in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2006, 06:22
  4. Traction Control Light coming on intermittently...
    By imported_Stewart in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2006, 21:55
  5. Help! Engine Warning light on :(
    By edmanning in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th May 2005, 19:05
