Results 1 to 33 of 33
Like Tree7Likes
  • 1 Post By PetrolDave
  • 1 Post By B5NUT
  • 1 Post By jdp1962
  • 1 Post By A4_MaJiK
  • 1 Post By kite
  • 1 Post By leegsi
  • 1 Post By jdp1962
Thread: Possible stuck heater flaps
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    For a while now, I've been getting all my hot air through the dash vents, and only cool air through the footwell vents. So I'm wondering if I've got a problem with heater flap motors. I don't have VCDS, and a quick search of the VCDS users map suggests no current members within 20 miles or so.
    So I'm going to have a go and removing the glovebox and attempting a visual check. IIRC, there are five hex bolts to remove, but do I have to remove the CD changer as well? Or will the glovebox come out with the changer in place?
    Once I have got it out, any tips on what to look for? I'm presuming it's a case of pressing all the different directional buttons on the CC panel and watching what the levers do.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,534
    You have to remove the CD changer as there's a bolt above it holding the glovebox in place.
    If your problem is a cold passenger footwell, then with the glovebox off and the engine up to normal temperature & running change the passenger footwell temperature up & down and you should see a motor moving.
    BTW the driver and passenger footwell are separately controlled, so there's an equivalent motor on the drivers side of the heater.
    jdp1962 likes this.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    Quote Originally Posted by PetrolDave View Post
    Thanks, Dave.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    Ok, had my glovebox out this morning, and a look inside. I'm pretty certain I've identified a malfunctioning motor, the one sitting below the red linkage in the following photo:
    I unscrewed the motor, detached it from the linkage, manipulated the red linkage to a point where it was allowing air to flow to the footwells, and replaced the glovebox. Not been out in the car yet, so haven't had a chance to test it. Meanwhile, here's the motor I've taken off.
    The red lever that attaches to the red linkage will not budge when I try to move it. So I removed the cover to reveal this:
    I'm going to have a go at lubricating the mechansim, see if I can get it moving. If not, I've got the part number (8E2820511A) and located a couple of used ones on eBay for around £30. Of course, they could be problematic too, so I will also check out the price of a new one.
    I removed the lower dash cover on the driver's side, but couldn't see a similar assembly on that side. I decided to leave well alone rather than poke about too much and risk disturbing something.
    Will report further on whether I can get this motor moving again.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    Ok, so the red lever is still stuck fast, despite liberal applications of WD40 and silicone spray. I'm reluctant to start pulling the motor innards apart (I'm not very good at these things) but is there a knack to freeing them up? Am I right in assuming the lever will turn manually when functioning correctly or will it only move when the motor is connected up and receiving power?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    Ok, so I managed to dismantle the innards.
    First the good news, the motor spindle turns freely when it's disengaged. That suggests the motor is not seized. Secondly, the cream coloured cog (which is connected to the red lever on t'other side turns freely when disengaged. However, as soon as the green spindle is slotted back into place and engaged with the wheel, all movement stops.
    I need to find a way of getting the wheel to move when the spindle is in place.
    Will report progress if I make any.
    2,175
    You can pick the motor units up from ebay for around £30. I just replaced one in an A6 that had a similar fault.
    jdp1962 likes this.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    If the car blows warm airs to the foot wells tomorrow morning, I'll be reasonably confident I removed the right motor, and will order up a new one from eBay.
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Had this problem the other day, pulled part to bits. Motor was fine but the cog mechanism was a bit stiff so kept WD40'ing and moving and eventually started to work okay. Am keeping an eye on it though just in case it sticks again.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    scotty76's Avatar
    Nov 2011
    Berkshire
    1,081
    Sorry for a slight thread hijack but does ticking from behind the dash signify similar issues? I've not noticed any problems but just wondered.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    It could be. Mine clicks and ticks quite a bit.
    scotty76 likes this.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    OK, well just drove to work, and the result is mixed. I did get air flow to the footwells (including through the small grills on the side of the transmission tunnel), but it was all warm on the driver's side and cool on the passenger side. Same with the dash and screen vents too.
    So at least I know I need to replace the motor I took off, but I have a feeling when I do, I may still have some more digging to do.
    Sep 2013
    Portsmouth
    245
    The way it's geared you will find it difficult to move.
    You can put 12v direct to the motor and see if it moves.
    Mine was the coloured bit going through the black plastic bit/casing was tight so used some wet and dry to open the hole up a bit and now it works fine
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    Quote Originally Posted by leegsi View Post
    Thanks. I will try that
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Wow Jeff! Good to see you tackling this yourself and not taking it to a garage. Hope you get it sorted in the end. Always a good feeling after you've accomplished it.
    All the best, Azeem.
    jdp1962 likes this.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    Quote Originally Posted by A4_MaJiK View Post
    Thanks for the vote of confidence Azeem, however my attempts to fix myself usually end up with a bigger garage bill for fixing the original fault and the damage I did.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    Just spoke to local Audi dealer, a new flap motor is £120!!!!!!
    scotty76's Avatar
    Nov 2011
    Berkshire
    1,081
    Quote Originally Posted by jdp1962 View Post
    They really to do take the p1ss sometimes.
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    £120! When all it is is a few bits of plastic cog and a small electric motor you could find in a trainset?
    Nathan
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    I'll have a crack at reconnecting my existing and newly lubricated motor, see if it moves when blasted with 12V of power. If not, then it's off to the Bay.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,576
    try a car breaker too.
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    Just reconnected old motor to power supply. Creaked a bit but didn't turn. So now I know it's borked. Moved the linkage up and down a bit by hand, and sorted out the hot/cold flow side of things.
    So all I've got to do now decide whether to buy a used motor for £27.50 (that's come from an older car than mine) or £120 for a new one. That's an absurd sum of money to pay for something the innards of which look like they came out of a scalextric set, but I don't want to be doing this again in a few months' time.
    kite's Avatar
    Oct 2007
    East Berks
    675
    Quattrojames is breaking his old car, he msy have a motor going spare. Send him a PM.
    jdp1962 likes this.
    A4 (b6) 2.5 TDi QS Saloon.
    Sep 2013
    Portsmouth
    245
    Take the motor back out from the housing and give it 12v to see if it moves. If it does you know it's the cogs binding somewhere.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    I've already done that; I know the motor is working but I have't been able to free the cogs, despite a lot of jiggling and greasing.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    Quote Originally Posted by kite View Post
    Cheers ,Kite, will do
  28. #27
    Sep 2013
    Portsmouth
    245
    Take the motor out and turn the cogs by hand and take the cogs out one by one till its free.
    Out of 3 I have repaired its always been the coloured arm in the round hole being tight.
    jdp1962 likes this.
  29. #28
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    I tried doing that, Leegsi, but just couldn't get it to work. I guess it was just beyond my level of incompetence. Just spoke to TPS, and they can go a new one minus the 20% dealer markup. I'll pick it up tomorrow.
    Meanwhile, I'm just off to fit my S-Line door blades which Craigcull sent me. Happy days!
  30. #29
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    Well, I've swapped the motor on the passenger side, and all is well there. I think I might still have a problem though, as the air through the dash vents still a fair bit hotter on the driver's side than on the passenger side.
    Does anyone have a picture of the motor that directs warm air to the driver's footwell?
    or do I need to get the system reset with VCDS?
  31. #30
    27,108
    Grab vcds & do a basic setting 001 in module 08 hvac, this will reset the flaps, if you've moved things about it may create an issue, so make sure its been refitted in the same position as it was removed, although this may be the only way it may fit based on current location that is, but I recall a note in elsawin stating about how to remove/refit & I cant recall atm, but something in a distant memory mentioned about positioning.
  32. #31
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    Thanks, Nigel. I'll get my local indie to reset it. They're pretty reasonable.
  33. #32
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    I said they were pretty reasonable. Sanspeed did the basic settings reset free of charge. All now working fine. They did say it could come back if there's an intermittent fault, but will cross that bridge if and when I come to it.
  34. #33
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    Well I came to the bridge rather sooner than I'd hoped.For the first fifteen minutes of my journey to work this morning, all was well with gentle breezes of slightly warm air distributing evenly throughout the car. Then all of a sudden, it began once more to send concentrated heat to the driver's side dash vents. Back to square one, I'm afraid.
  1. Heater flap motors - where to buy
    By jbcalvin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th February 2014, 19:29
  2. Heater flap solenoid's
    By Greeny233 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th October 2013, 21:09
  3. Heater flap repair - Bit of DIY
    By BlackQuat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th October 2012, 12:33
  4. Has the heater flap gone? no hot air
    By JA50N in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th April 2012, 21:05
  5. has anyone got a heater flap?
    By rasA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd September 2010, 17:44
