Sky InsuranceJMB Retrofits
Results 1 to 13 of 13
    May 2012
    Derby
    Engine temp problem...
    Hi all,
    Problem I have is the car is taking longer than average to warm up, during this process with the
    blower on low and on max temp and if I'm in traffic the temp will go down back to cold.
    Once warm on 90degrees again if in traffic or stationary the temp will drop down again.
    I have changed the thermostat with a genuine replacement, filled the cooling system with
    antifreeze/water and blead accordingly...the problem is still there
    So I have also changed the engine coolant temperature sensor, lost a few litres of coolant so
    repeated the process of filling the coolant and blead again.
    Unfortunately the problem still persists!
    Any advice/feedback will be appreciated
    Many thanks
    Car in question is a Audi A4 2.0 tdi sline 2007 B7
    V6 Quatt's Avatar
    Feb 2008
    783
    May be temp sensor?
    Torque the Torque
    Craig Cull's Avatar
    Oct 2011
    Leeds uk
    1,135
    Visit Craig Cull's Youtube Channel
    I had a similar problem when bleeding mine last week. I found it had an air lock. I left it running for a while, turned it off, then left the top off the coolant and let it bleed its self, when I came back out the water had sunk to the bottom, I then filled it up, fired it up and continued to bleed as normal. Heaters got warm and the problem was solved. Took me nearly 2 hours like but it's worth a blast
    K04 hybrid turbo. S3 injectors, Autotech hpfp internals, RS4 fuel pressure regulator, custom FMIC, APR carbonio intake, decat pipe, milltek cat back non resonated 100mm tips, unicorn developments custom remap, launch control and flat shift. Valet mode, economy map and full power map options. Stage 3 southbend clutch with single mass flywheel, Eibach pro street coilovers, eibach front and rear anti roll bars, porsche cayenne 6 pot calipers front, S4 rear brake conversion.
    May 2012
    Derby
    Quote Originally Posted by V6 Quatt View Post
    May be temp sensor?
    Change it again?..
    May 2012
    Derby
    Quote Originally Posted by craigcull View Post
    Iv more or less blead the car with the process you mentiioned...
    but worth another try...
    May 2012
    Derby
    Blead the cooling system again still the same...
    It takes average time for the car to warm up to 90degrees
    providing the blower is off, with them on and stationary it will fall down
    to 60degrees but what i find strange is the heaters are blowing piping
    hot air all around the cabin regardless of the temp.
    The rad hose is not getting as hot as it should and the thermostat housing is
    cool...
    Jun 2013
    235
    Thermostat in wrong way round !!!
    May 2012
    Derby
    Quote Originally Posted by joinerman View Post
    Lol i wish it was!
    Its defiantly in the right way!
    Mar 2013
    Berkshire
    391
    May be worth noting that there are 2 cooling sensors. One is green the other is grey.
    Best scan the car if you can and see if anything is coming up.
    May 2012
    Derby
    Iv had the car scanned no codes, apart from my parking sensors as one has given up.
    I assumed there is only one coolant sensor on the back of the block?...cannot find another one...
    Water is not circutlating around the block im now assuming my water pump is weak and looking into that..
    Jul 2007
    770
    There s/b another sensor on the rad to control the fan but that wont be your prob.Thing is if the engine is warming up in a reasonable time not overheating and the heater is 100% then all is as it should be apart from the gauge itself.These are not accurate devizes
    May 2012
    Derby
    Quote Originally Posted by Mike B View Post
    Agreed, but the the engine is staying cold, the lower pipe coming off the rad and leading onto
    the thermostat is always ice cold even after driving for a few hours the water is not circulating
    and the engine is luke warmish...not hot as it should be
    jus came back from the garage...changed the waterpump and while i was at it changed the
    timing belt aswel...so new water pump, thermostat and cooling temp sensor...
    going to send the radiator off to get flushed out on monday and pressure tested...
    will post results...
    Craig Cull's Avatar
    Oct 2011
    Leeds uk
    1,135
    Hope you manage to find the problem mate :/
  1. A problem starting when engine temp is at half way......
    By BigWillyStyle in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th August 2012, 22:48
  2. Engine Temp Dial - AND Air Con Problem
    By A13X-A3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2007, 20:38
  3. Best engine temp to check oil level?
    By A3_TOBES in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th April 2006, 14:08
  4. Engine Temp in Winter
    By Marko in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd February 2006, 18:35
  5. Water Temp Problem
    By m_o_w_g_l_i in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th December 2005, 23:16
