EM TuningJMB Retrofits
    Oct 2013
    13
    Rear bulb cluster not working
    My left indicator when sat in the car is ticking twice as fast as normal, front and side light indicator bulbs are fine but the rear cluster on the car( not the ones on the bootlid) none of the lights are working. One bulb had blown so replaced that but still the same. Replaced all 3 bulbs but still not joy! Help..
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    727
    Could be the pins on the connector have burnt out. Happened on mine. Replaced the bulb holder and all is good again. Assume you've obvious check the fuse
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
  1. Replies: 9
    Last Post: 10th June 2010, 08:22
  2. Rear demister switch not working
    By voteforpedro in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th October 2009, 09:03
  3. Rear screen demister not working
    By NLM13 in forum A8/S8 forum
    Last Post: 17th October 2008, 08:32
  4. Rear door light not working
    By ang12el in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th December 2007, 09:12
  5. Rear speakers/DIS not working
    By dermot in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th August 2005, 11:57
