Results 1 to 12 of 12
Like Tree3Likes
  • 1 Post By Macdoon
  • 1 Post By Paul B7
  • 1 Post By Raymond999
Thread: Buying a4 2.0tdi
    Raymond999's Avatar
    Jan 2014
    37
    Buying a4 2.0tdi
    Hi I am going to look at a4 s line 2.0 tdi 170 57 plate in red with 72000 on the clock at the weekend with the hope buying,
    But have been reading some real bad reviews and story's on the 2.0 tdi engine on the Internet.
    Can someone please put mind at rest or is 2.0tdi unit that bad.
    The car is up at 9950 and it's very big lump of cash for me spend, any advice would be appreciate.
    Thanks in advance raymond
    Anthony566's Avatar
    Nov 2013
    North East
    614
    Is this a garage or private sale ?
    1 check that it has a full Audi service history
    2 contact the garage it has been serviced at and check the history
    3 ask about oil consumption make sure it's not excessive
    4 see if there is someone on the forum close to you with VCDS and get them to connect to the car to confirm mileage and check for error codes
    5 ask if this has had the dpf or cat removed or mapped
    6 don't just drive it round the corner go do a good 20 mile test drive get it at running temp and also as the seller not to run the car on the day until you get there so you can do a proper cold start.
    I'm sure other will have a few other things to look for.
    2013 A4 2.0 TDi 177 quattro Black Edition - Glacier White
    Raymond999's Avatar
    Jan 2014
    37
    Hi it's garage sale, and the car has been either chipped or remapped but not sure which.
    Should this have bering on my desion weath to buy or not.
    Salesman has told me the car has wanted for nothing over its life, but we will see if that true when go to see her.
    He also said its timing belt water pump and injectors done.
    Anthony566's Avatar
    Nov 2013
    North East
    614
    Just check its service history and find out who did the map, check for excessive smoke there will be a bit if it's had the DPF removed and find someone who can plug into the car.
    I'm sure it will be fine but nothing wrong with making sure.
    Raymond999's Avatar
    Jan 2014
    37
    Cheers, really looking forward to it, I am just scared of what been reading and after owning BMW 330ci which was a complete @#&&ing nightmare from start to finish I don't want to get shafted again.
    If all go's well at weekend I will pop a few pic up of her.
    Anthony566's Avatar
    Nov 2013
    North East
    614
    When I was looking at this version the only common issue I could find was this one so check if this has been done and if not contact Audi the Audi service centres used should be in the service book.
    "There is an 'unofficial' recall, in that, if you have one of these cars, a quick call to Audi customer services, and they will set up an appointment with your closest dealer and replace all the Injectors (modified ones) and Loom free of charge."
    I am sure some 170 owners will be along soon to confirm or deny this and point out any other things to look out for.
    Jun 2007
    624
    Quote Originally Posted by Anthony566 View Post
    When I was looking at this version the only common issue I could find was this one so check if this has been done and if not contact Audi the Audi service centres used should be in the service book."There is an 'unofficial' recall, in that, if you have one of these cars, a quick call to Audi customer services, and they will set up an appointment with your closest dealer and replace all the Injectors (modified ones) and Loom free of charge."I am sure some 170 owners will be along soon to confirm or deny this and point out any other things to look out for.
    Was this recall only on the 170, not on the 143?
    Macdoon's Avatar
    Essex
    1,568
    2.0l Tdi 170 - had mine 3 1/2 yrs,
    Turbo replaced 40k
    Audi recall to replace injectors 50k (smoked ever since)
    Oil pump/balancer shaft/hex drive key upgraded (preventative measure) 75k
    Coolant temp sensor replaced 85k
    Oil cooler replaced 88k
    Oil level sensor replaced 90k
    EGR valve had been off with every major service and cleaned
    Rough idle/smoking on cold start up tried everything to resolve
    My car has wanted for nothing, but having owned 20 Audi's over 26yrs, this one has been the worst car for issues, that said i have enjoyed it and kept it longer than any other. There are thousands out there that have high miles and no issues.
    My advice check to see if any of the above have been done.
    If it's been looked after by an enthuisast you should be fine
    Mac
    CHEZ likes this.
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler, LED interior, LED number plate lights, Brushed steel vinyl wrapped interior.
    North East
    607
    Quote Originally Posted by Raymond999 View Post
    I have driven Audis for 30 years and the 2.0tdi IS the worst engine they have EVER produced.
    My recommendation is avoid the 2.0tdi units like the plague and if you must have a diesel get a 1.9tdi or a 3.0tdi.
    Macdoon likes this.
    Raymond999's Avatar
    Jan 2014
    37
    To late bought her yesterday, going in to audi specialist on Monday to get the balance shaft upgraded so it can't go and have having the pdf filter taking out and then the car mapped.
    Avnt likes this.
    North East
    607
    I wish you well with the car , you may be one of the lucky ones and have few issues. good luck and welcome to the forum.
    Paul B7
    Anthony566's Avatar
    Nov 2013
    North East
    614
    Happy new car .... Looks stunning from the photo just keep on to of the servicing and follow up on it's history and I'm sure you will be fine.
  1. Advice on buying a 3.0tdi
    By Mikemc in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 23rd October 2013, 09:06
  2. 3.0tdi Cab S-Line Quattro.To buy or not to buy???? Advise please
    By RacDave in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th January 2011, 16:14
  3. Buying 55reg 2.0tdi s line
    By danotto in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th December 2009, 20:00
  4. Advice on buying new A3 2.0TDi SLine Sportback please...
    By SMc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th May 2007, 11:32
  5. Buying a A4 2.0TDI, go for the S-Line?
    By andyollie in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th November 2005, 16:03
