Volks AutosSky Insurance
Like Tree1Likes
  • 1 Post By joinerman
Thread: Spare wheel water leak, a cure !!
    Jun 2013
    258
    Been trying to trace where the water gets in to the wheel well on my estate, think I've cracked it, at each corner of the rubber seal in the pic there's a small hole that lets water under the trim & into the well, took the inner panel off to expose two water lines from the corners direct to the well, dried everything off & refitted everything then went around under where the rubber lips over the inner panel with a fine bead of silicone, pressed along the rubber so it just oozed out the a wet finger to clean it up, seems to be working.
    tut_gareth likes this.
    Oct 2013
    373
    Silicone wont last long, what you want is a pu type sealant about 7 pounds a tube.
    Ive seen many boot seals where the grippy bit just doesnt grip enough, cure remove the seal nip it up with pliers and refit it carefully, dont use a hammer as it spreads the seal apart again.
    Jun 2013
    258
    Hmm sorry to disagree re use of silicone, used it on several of my other vehicles & all have been fine using it, some for years.
    Oct 2013
    373
    I see it all the time at work on trucks and on boats, silicone may fill the gap but the edges never stay stuck and always come away
    Same as in the shower etc eventually it fails.
    I realise that trucks and boats are probably the severe end of most peoples usage but its what I see day in day out.
    Jun 2013
    258
    yes I know what you mean re edges curling up, I use some stuff called Dunbrik, its a class 2 gas flue block sealant, it's bloody good and never had a problem with curling, unlike the stuff you get from b and q or wicks etc
    Jun 2013
    258
    Well it's been three weeks & boy have we had some rain, thought i would check the well today, one other mod i did was to nick a corner out of the grommit seen in the pic bit crude i know but i only have one useful hand at the moment, helps with ventilation, anyways well was bone dry.
  1. Help, spare wheel well full of water
    By Macdoon in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th July 2012, 23:35
  2. Water in Spare Wheel Well ?
    By everogere in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th October 2009, 19:07
  3. Rear Wash Wipe, Water leaking from wheel arch!
    By Gajjii in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2006, 01:13
  4. Spare Wheel
    By Speedy in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th November 2003, 21:24
  5. Help, S4 water leak!
    By Futureman in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st August 2003, 20:11
