    Dec 2013
    11
    A4 Avant small coolant leak
    Hi Guys, I was wondering if someone could help me out here. I've just bought a 2008 1.9 TDi A4 Avant s-line. I have noticed that there is a very small leak around the thermostat housing area.
    It's this metal pipe (second picture arrowed) I think which goes into where the thermostat goes and then into the heating matrix for the inside of the car. I can feel it's a little damp under the pipe and there is a small ledge for it to drip onto so there is a small amount on there.
    Can anyone shed some light on this for me to fix/how much it would cost from a dealer to fix?
    I don't think it's very serious at the moment because when I unscrew the expansion tank it has got lots of pressure.
    Many thanks
    Tom
    27,129
    I reckon a new o-ring would possibly fix this unless the pipes been damaged, if the stats been changed its possible o-ring was fitted badly, it would need removing ideally to inspect & resolve, having a spare new o-ring to fit.
    Dec 2013
    11
    It doesn't look damaged....it's just a metal pipe. Do you know if you can just order a single o-ring for it?
    27,129
    Yes you can.
  1. Coolant leak A4 Avant 54 plate
    By pgy531 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th December 2009, 11:28
  2. Coolant leak
    By petewon in forum General Technical / How To
    Last Post: 5th October 2006, 21:33
  3. Problems with S3, suspect coolant leak & Turbo dump/recirc Valve noise??
    By fasteddie in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2006, 17:17
  4. coolant leak - need to id name of pipe
    By Fraser in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th March 2006, 01:03
  5. Possible coolant leak, any ideas?
    By jgrand in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2005, 11:46
