After a drive in some very wet and miserable conditions my ESp light and EPC light came on the engine went into limp mode briefly. so I got the old cable out and plugged it in. the car had been fine up until this point.
Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8E3 910 560 HW: 4E0 907 560
Component: 4.2L V8/5V G 0020
Revision: --H01--- Serial number:
Coding: 0011774
Shop #: WSC 00672 785 00200
VCID: E5C1FF742CB7EE36875-80B0
3 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - Intermittent
16691 - Cylinder 7
P0307 - 001 - Misfire Detected - Intermittent
18047 - Accelerator Position Sensor 1/2 (G79/G185)
P1639 - 008 - Implausible Signal
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 M HW: 09L 927 156 B
Component: AG6 09L 4,2 MPI RdW 0030
Revision: --H01--- Serial number: 4220719
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 3169DB24A8FFF2962BD-8064
1 Fault Found:
006241 - Throttle Position Sensor (G79)
P1861 - 000 - Error Message from ECU
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 1376 /min
RPM: 1248 /min
RPM: 1152 /min
(no units): 14.0
(no units): 39.0
Temperature: 59.0°C
T.B. Angle: 60.0°
I've cleared the faults but haven't had a chance to drive it yet. I was wondering if this could have been caused by the ECU getting water in it or am I just being hopeful (it was an horrendous day)
Coding: 0011774
3 Faults Found:
16691 - Cylinder 7
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 1376 /min
RPM: 1248 /min
RPM: 1152 /min
(no units): 14.0
(no units): 39.0
Temperature: 59.0°C
T.B. Angle: 60.0°
