Chris NottBadger5
Page 2 of 2 FirstFirst 12
Results 41 to 55 of 55
Like Tree5Likes
Thread: Tom's Quattro Special Ed.
  1. #41
    Sep 2013
    48
    Should probably update this...
    So last weekend i set about fitting the coilys. All in all went pretty well. Just some issues with getting the fronts out (rears just popped out surprisingly), after trying my hardest to do the fronts without taking the top control arms off, ended up taking them off. Out came the front struts. So pretty tight nuts and bolts but did it all without breaking a thing. I didn't put the rear adjusters in as i know ap's done. Will put the adjusters back in sometime then i can raise the front up too.
    Here's how it sits now...
    Took advantage of the nice weather and gave it a good wipe over
  3. #42
    Jan 2014
    Looks low, i was considering to buy AP coils too and now after this shots im sure that i will get this set for my Avant. Now need only a spacers and nice 19's concave wheels, but that only my opinion :P
    Well done.
  4. #43
    V6 Quatt's Avatar
    Feb 2008
    783
    How do the AP's ride against the Sline setup being its a Quattro?
    Quote Originally Posted by Andrewstw View Post
    Torque the Torque
  5. #44
    Sep 2013
    48
    Quote Originally Posted by V6 Quatt View Post
    Very well, 5x more comfy than the standard. Need to raise it up as handling had been compromised slightly on the fronts as they're rubbing badly. But all in all i'm very happy with them.
    Tom
  6. #45
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    751
    A B7 or a Mk5 GTi is on my list of things to buy next and can't decide. Can I ask why you chopped the GTi in? Did you have problems with it?
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel|Stage1Map
    WANTED: Audi A4 B7 or MK5 5Dr Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
  7. #46
    Sep 2013
    48
    Quote Originally Posted by JudderMan View Post
    It wasn't a GTI hehe. Was a PD105 with a gti front end and gti seats bla bla
  8. #47
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    751
    Ooosh, you fooled me then Both nice looking cars.
  9. #48
    Sep 2013
    48
    Cheers bud. To be honest they're both great shells. The engine is awesome! I'd have the AWD any day, but you it does has its benefits and draw backs (Fuel ) like everything. The MK5 handled better as it was lighter, can't really compare the power as they were two completely different engines. But the TFSI with quattro is in a league of its own! You'll have the same TFSI problems with both engines. Carbon build up on intake valves, PCV valve failure, Fuel pump lobe and follower, DV valve etc. The block itself is pretty bullet-proof!
  10. #49
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,680
    That's a lovely car you have there, Andrewstw.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
  11. #50
    Sep 2013
    48
    Quote Originally Posted by jdp1962 View Post
    Thank you very much
  12. #51
    Sep 2013
    48
    Just a couple snaps from last weekend:
    Got a southbend stage 2 endurance clutch coming from the states, so should be here in the next week or two. Says it's good for 450ft lb's so at least ill future proof that side of things
    Tom
  13. #52
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Like it a lot mate Got a link to the where you got the clutch from?
    Dark Vader Half sibling - MyThread
  14. #53
    Sep 2013
    48
    Quote Originally Posted by Ash B View Post
    I ordered it via euroenginuity (US company). I saw they had it for sale (advertised on instagram). They said they'd give a hell of a deal so it might have been one just lying around and they needed to shift it on so i got it for a pretty dam good price (including import duty).
    I was in contact with frank (frank@euroenginuity.com) and he was very helpful. Payed via Paypal and he sent it out 2 hours later! worth enquiring if you're interested for sure.
  15. #54
    Sep 2013
    48
    Clutch kit turned up
  16. #55
    Sep 2013
    48
    So put the rear adjusters back in as i wasn't really enjoying hitting every single piece of asphalt!
    Raised buy about 10mm. Also fitted my BSH PCV fix kit. Not sure there was anything wrong with the other one but at least that'll knock that one on the head.
  1. A4 s Line Quattro Special Edition - 235/35/18 vs 225/40/18
    By BADDave in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th May 2014, 12:23
  2. 2.0 tfsi S Line Quattro Special Edition (2006)
    By chrissy1502002 in forum For Sale/Wanted - Audi Cars
    Last Post: 14th January 2012, 17:53
  3. Replies: 7
    Last Post: 28th December 2011, 18:42
  4. A3 2.0T S-Line Quattro Special Edition
    Last Post: 3rd August 2011, 21:34
  5. My A4 2.0T S Line quattro special edition pics
    By Andy D in forum Photography & The Digital Darkroom
    Last Post: 29th June 2009, 15:58
