Chris NottSky Insurance
Like Tree1Likes
  • 1 Post By dpaz
Thread: Anyone who has retro-fitted Xenons?
    dpaz's Avatar
    Oct 2011
    Lincolnshire
    332
    Where did you route the hi-beam wires that run to the Central Electrics module?
    I'm struggling to find a grommet spare to route into the cabin. I've got past the firewall.
    The yanks go through the wheel well because of an extra grommet which UK cars don't have. Then the lucky (unlucky?) ones with an automatic gearbox can route via the empty grommet for the clutch line.
    Genuine Ross-Tech VCDS Owner - Lincolnshire & Humber Area
    Macdoon's Avatar
    Essex
    1,575
    Hi mate, my mate routed the wires through the back of the ECU box
    A4 B8 (09) 2.0 TFSI (211)
    Gloss black RS4 style mesh grille,fog grilles,splitter trim,A8 boot rings,rear diffuser & door blades.
    Ice White fogs, Tints, Black Badges, Dynamik boot spoiler, LED interior, LED number plate lights, Brushed steel vinyl wrapped interior,satin black exhaust tips, black calipers/red Audi rings.
    Dec 2012
    Birmingham
    295
    Visit SinghB7's Instagram Channel
    I think that is the best way for manual cars to take it under the ecu.
    For the autos the grommet between the ecu and brake servo is best.
    dpaz's Avatar
    Oct 2011
    Lincolnshire
    332
    Thanks everyone for the help.
    I went down Macdoon's advise after thinking about it for a bit and drilled a small 6mm hole in the ECU box next to where the other wires enter the box. I drilled quite high up on the box to avoid water and silicon'd the join afterwards on the inside. If you have a manual gearbox it has to be the easiest and best way to route these cables. You're straight into the cabin from there onwards and right next to where the central electrics module is.
    There is a grommet underneath the ECU box but it's just about impossible to get to without removing the ECU box entirely which is a huge job as one of the nuts which hold it down is impossible to get to without removing both wiper blades and the windscreen tray and even then you may have problems.
    What was originally planned to be a quick turnaround job ended up being a lot longer but the perfectionist that I am didn't probably help matters. Just got a slight gap to correct between the bumper and front wing at some point on the drivers side.
    Macdoon likes this.
  1. wee bit of help from anyone who has had a 2nd hand white cluster fitted
    By PH1L in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st July 2012, 15:08
  2. Does anyone on here retro fit xenons?
    By chrisa4quat in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd November 2011, 16:26
  3. Anyone who has fitted LCR top mounts?????
    By IOM-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2011, 09:36
  4. Xenon question for anyone who has them
    By Detector in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th November 2010, 17:54
  5. Anyone Retro fitted Xenon headlamps?
    By Stepho in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th January 2010, 22:36
