Volks AutosMonster Motorsport
    Jimmy Parko's Avatar
    Jun 2010
    Cleveland
    54
    Strange Noise from the glove box
    Hi All
    i have a 2008 A4 Avant 2.0 TFSI Special Edition.. The wife has noticed a strange noise coming form the Glove Box.. At first I thought it was something to do with the Climate Control but now I'm not too sure as it also happens when using the the Windscreen washers.
    Can an anyone ahead any light on the situation and will it be a costly repair??
    The noise is sort of like a intermittent grinding / vibration noise (before anyone asked I've checked the glove box for any if the wife's toys ha ha)
    thanks in advance
    Jimmy
    Audi S3 Quattro
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,470
    Sounds like one of the climate control motors or mechanism is sticking, probably the recirculation flap one as that closes when you operate the windscreen washers to stop you smelling the washer fluid(!). No I'm not kidding about that...
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Jun 2010
    Cleveland
    54
    Quote Originally Posted by PetrolDave View Post
    Thanks PetrolDave.. Makes perfect sense to be honest is it an easy fix or is it worth leaving till the next service (mid Janualry)
    regards Jimmy
    Audi S3 Quattro
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,470
    Drop the glovebox and you can see the motors. My passenger temperature one has done this twice - first time it was a jammed linkage (freed it and refitted it), second time the connector had a corroded pin which I just cleaned up. The motors are only held on by 3 Torx screws so they're really easy to remove.
    Not sure which one is the recirc one - maybe someone else can clarify?
    It's definitely a job I would do rather than get ripped off by a dealer to do!
    Dec 2012
    Birmingham
    218
    I had the same problem on mine, i removed the glove box (make sure you do not disconnect the plug otherwise airbag light will come on and you will have to pay to have it cleared by a garage)
    The motor is right infront, i put 2 cable ties around it and tightened the housing together and it stopped.
    A year later and its still fine.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,470
    Quote Originally Posted by SinghB7 View Post
    If you or a friend have VCDS you/they can clear the airbag light too.
  1. Strange noise from the rear at low speed when turning
    By 86fran in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2013, 20:28
  2. help.. odd noise from behind glove box.
    By cjhill in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2012, 16:08
  3. Strange noise from the cabin heater blower
    By brads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th December 2011, 19:57
  4. Strange noises from the engine
    By tfox in forum Diesel forum
    Last Post: 5th June 2006, 12:14
  5. anyone got a creaking from the glove box lid?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th April 2005, 09:13
