EM TuningBadger5
    Jan 2012
    59
    Cam position sensor
    In another post I've described some problems I'm having with rough idle, it's been suggested that cam position sensor may be the root of it, so I'm considering giving it a punt if it's not a tough/expensive part to fit.
    I've had a look around what I can but I can't find the position of this thing:
    METZGER Sensor, ignition pulse Black (0903022) buy cheap online - AUDI, SEAT, SKODA, VW
    On a 2.0tfsi (bgb).
    Can anyone point me at it or ideally a procedure to swap it out?
    Is also be interested to hear from anyone who can explain the function of the cam position sensor (apart from the obvious) and what symptoms of a failing part might be.
    Cheers.
    Oct 2013
    367
    Have you considered the option the cam position sensor might be telling the truth and your cam timing could be out or the belt could be slack?
  1. cam position sensor and warranty companies
    By leeoliver86 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st September 2013, 00:19
  2. Cam shaft position sensor fault????
    By jay1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2013, 17:02
  3. camshaft position sensor or timing?
    By p14va in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2007, 11:27
  4. throttle position sensor
    By turboaudi in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd March 2007, 14:22
  5. Camshaft Position Sensor
    By imported_mustwin1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2005, 13:32
