trickybusa
Morning All,
I have fitted the cruise and dis stalks to my 2006 A4 avant s line with multi function steering wheel and with Mike Fosters help (thank you) we managed to enable the dis function and I earthed out pin one to get rid of the washer level warning which is great. The problem I have now is I can not enable the cruise, when I go into 01-engine then into coding II- 11 and put in the activation code 11463-cruise activation and then click DO IT an error message comes up saying,
Login code not accepted by controller!
You will have to turn the ignition off
for a while before trying again.
Error22: Conditions not correct or request sequence error.
So not being a Vagcom guru i'm a bit stumped can anyone shed a bit of light on this for me as I've obviously missed a step out or have some thing missing.
Also for info when I go into 16-steering wheel then into meas. blocks-08 I can see that the car and Vagcom can see the stalk is fitted because when I move the stalk it says cruise switch on or off then it says resume etc so it does see it.
Cheers all,
Cheers all,
