Hi all!
Recently had an issue with the recirc flap positioning motor behind the glovebox.
Removed the glovebox, diagnosed the faulty motor, repaired the unit and put back together.
Whilst the glovebox was removed I had the 'Passenger Airbag Off' yellow warning light flashing in the centre console and the red 'Airbag' warning light in the dash (read this is an MOT failure and if its on means all airbags are disabled?!? Eeek).
Once I had reinstalled the glovebox, reconnecting the yellow connector at the very back, the yellow light has gone out bu the red dash warning light is still on?! Is this just because it has registered a 'fault' with the airbag whilst the isolation switch was removed and just needs clearing?!
I don't have access to Vagcom etc! Anyone in Plymouth got it that could help?!
