EM TuningChris Nott
Results 1 to 11 of 11
    Molnboman's Avatar
    Airbag redwarning light?
    New to this one.....airbag warning has come up in red on the dash. The hasn't happened before for me and my Mrs is driving the car right now....so not sure what the craic is. Car is running as normal and she insists she hasn't hit anything. Is the car safe to drive until I get it checked out? Any advice would be well received.
    Please advise,
    BR
    A
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Sometimes, the airbag light can be triggered by the front seat adjuster being moved. I have a vague memory of this happening on one of my B5s about ten years ago. I seem to recall a VCDS reset doing the trick. Until it is cleared, I have a feeling the airbag circuit will be inactive.
    So defintely get it looked at.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Molnboman's Avatar
    Thanks J, so is it safe to drive in your humble opinion...ie: there's not a chance it's going to explode on her nice winter clothes...God forbid!...I won't you hold you to this natch....just that I can't get the car to the garage till am back in IKEA land.
    Best Wishes,
    Allan
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Quote Originally Posted by Molnboman View Post
    Best Wishes,
    Allan
    As I said, if the warning light is on, the airbags become inactive, so no it isn't going to go off in her face (but not even if she crashes and needs it to, though).
    North East
    607
    Quote Originally Posted by jdp1962 View Post
    Your memory is good!
    I used to experience the same issue on my 1998 A4.
    Molnboman's Avatar
    Cheers Lads,
    BR
    A
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    551
    Add GeoffDunk on Facebook
    Everyone is correct, the Red light highlights a fault and the bags are deactivated. The light is red to warn you they won't go off in the event of an accident.
    Another issue will be the MOT, with the light on it will fail a UK MOT and other safety tests across Europe if you are outside of the UK. I notice you are in Sweden, I would assume the its a failure there is the Swedish legislation is far stricter than the UK from memory (they gave us DRL's).
    The bottom line is that its in an unsafe state so should be dealt with.
    Audi S4 quattro in Dolphin Grey Metallic, Silver leather, carbon inlays, RNS-E, 6 speed manual, electrically adjustable & heated seats, xenon headlights with power wash, cruise control, storage pack, 18" OEM RS4 wheels, RS4 ARB, LED lighting upgrade, FASH plus every bill since new.
    Molnboman's Avatar
    Cheers Geoff, no worries I am aware that it would fail an MOT natch ( Thankfully mine sailed it in September )....just wanted to make sure that the car would safe to drive, until I get it over to the garage....hopefully the lads can scan it today if they are working that is.....It is Swedenshire! Keep you all posted on the outcome.
    A
    Molnboman's Avatar
    Hooked it up to get a code reading this morning at the local garage. Codes came up on the passenger side....they didnae have time to check it further. Have to wait till am back on the 16th before they can check it out proper. Might check the passenger seat cable underneath myself....but found it tricky to remover the cover....guess it your driver's side. Keep you posted.
    BR
    Allan
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    pull plug clean up refit and clear light
    if not sorted theres a guide how to sort it
    by cuting plug off and rejoining with a audi repair wire
    very comon and iv personaly done over 10 to b6 and b7
    Molnboman's Avatar
    Cheers Bez...aye, I saw the fix and it freaked me out a bit! hahaha I try the clean up first...and rock on from there!
    BR
    A
  1. Airbag warning light
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2007, 18:05
  2. A4 airbag warning light
    By PembsA4TDi in forum VCDS (formerly VAG-COM) forum
    Last Post: 17th December 2006, 09:46
  3. Airbag Warning Light
    By reynot01 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th February 2005, 14:20
  4. Airbag Warning Light
    By imported_ZeroK66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st November 2004, 23:01
  5. airbag warning light stays on
    By manikm in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th May 2004, 23:32
