Sky InsuranceJMB Retrofits
Results 1 to 11 of 11
Thread: Losing coolant
    Macdoon's Avatar
    Essex
    1,569
    Losing coolant
    This is driving me mad, trawled soooo many threads........
    Losing coolant (slow loss), no external leaks (pressure test done), so obviously it's going somewhere.
    Anyone else had this- my mate is thinking possible EGR cooler internal leak.
    Short of waiting for it to get worse, I'm at a loss.
    Still got the smoking/ rough idle issue from cold start until run up to temp.
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler, LED interior, LED number plate lights, Brushed steel vinyl wrapped interior.
    Avnt's Avatar
    Mar 2013
    228
    Losing coolant
    Could u pressure the system to show any leaks?
    Should really have read the pressure test done thing. 😑
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    read his post hes had that done
    Oct 2013
    373
    Read his post hes noticed he said that
    dpaz's Avatar
    Oct 2011
    Lincolnshire
    332
    Could try K-Seal (or similar). I know VW tech's use it themselves. It's a solution that you add to coolant and it repairs and slight leaks in the system.
    How does K-Seal work? - Stop, fix and repair coolant leak
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    sounds like a porus head/ leaky gasket or similar, that'd cause all of your issues inc rough cold start.
    Oct 2013
    373
    Second k-seal ive used it a few times and its worked, in one case the rad is still water tight over 4 years later!
    Macdoon's Avatar
    Essex
    1,569
    Quote Originally Posted by Broken Byzan View Post
    Not that I know much about engines, but would this be indicated on a dye & pressure test?
    Big Al's Avatar
    A4 2.0T FSI engine knackered!
    May 2011
    West Midlands
    304
    Check the turbo coolant lines? My TFSI had small leaks but because of the turbo heat, it was being burnt/evaporated off leaving small residues only. Good luck with the fix!
    Audi A4 B7 2004 red 2.0 TFSI Quattro Sport saloon, Servotronic steering, MFSW, CDIS, DRL with Coming Home, auto dual xenon lights/wipers/mirrors, split folding rear seats, 3rd headrest, centre armrest, Isofix mounts, RS4 rear ARB, pedals & carbon dash trims; Audi TTS 9Jx18alloys (2 sets), Yokohama AD08 summer, Conti TS830P winter 245/40/18 tyres, TPI 15/20 spacers/lockers, Pipercross filter, GFB DV+ turbo valve, NGK BKR7EIX plugs, Osram Silverstar Xenarc D1S bulbs. Build thread
    Macdoon's Avatar
    Essex
    1,569
    Cheers Al, every idea and bit of info helps
    Macdoon's Avatar
    Essex
    1,569
    Update..... looked into this issue more thoroughly, turns out that there has been a known issue with early EGR coolers, Audi have revised the cooler a couple of times. So... no obvious signs of water anywhere around the engine bay. No pool of water under car in the morning. Losing about 1 litre of coolant every 2 days. Rough idle on cold start and smoking. Took the EGR valve apart, full of sludge again, only cleaned out just over a year ago, this time tho' the soot was damp, so water must be getting through. New EGR cooler ordered, £275 grrr
  1. 2.0 TFSi losing coolant
    By mancdan in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th February 2012, 19:16
  2. Audi A3 TDI - losing coolant fast
    By Das Chin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th July 2011, 12:30
  3. Losing Coolant!
    By bhavin1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th December 2010, 20:25
  4. a6 losing coolant
    By JimC64 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th July 2009, 18:23
  5. Losing coolant
    By adbett in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th October 2007, 21:21
