Chris NottBadger5
    Oct 2013
    13
    LED interior light replacement
    hi all, I have just replaced boot rear and front interiors to LEDs but the two small twist map lights in the front has anyone got an ebay link for them?? thanks
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,703
    Contact forum member T8ups. He'll sort you out.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,355
    Sep 2013
    63
    here the baynet is t4w which is also ba9s . I used myself osram 6000k interior leds no problem and definitely the dogs balls better than anything else came across if you splash the cash.
    Only bulb i couldnt get was 42mm festoon led from osram but i used 6000k off ebay and one bulb failed after three days so got a replacement, definitely makes a difference the lighting to what audi had used.
    Nov 2011
    213
    Quote Originally Posted by jdp1962 View Post
    definitely
  1. LED Interior light bulbs fitted - footwell, centre and map lights
    By mattandrew in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th June 2011, 17:23
  2. LED INTERIOR LIGHTS
    By phoenixv6quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th December 2010, 10:44
  3. Another led Interior light nearlly done!
    By mac1403 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th April 2009, 23:33
  4. LED interior light problem.......
    By Nessy in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th November 2008, 20:34
  5. LED Interior Light Kit .....
    By cliveywolves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th February 2007, 09:00
