Volks AutosMonster Motorsport
Results 1 to 8 of 8
    D2NY G's Avatar
    Apr 2011
    1,041
    Temp Rising & Dropping? Thermostat
    Gents :D
    Driving home other night and noticed the car dropped from its normal steady 90 on the temp gauge, dropped to 70 then raised back upto 90 and seamt fine. Is this an early warning of the thermostat going?
    So all that am gunna ask, whats the damage on one of these bits will it solve ma problem, easy fix ect?
    Cheers lads
    Mar 2013
    Berkshire
    399
    Quote Originally Posted by D2NY G View Post
    Gents :D
    Cheers lads
    Morning, it could possibly be a sensor. If you can scan your car and you see the following:
    1 Fault Found:
    008577 - Performance Malfunction in Cooling System
    P2181 - 008 - - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: xxxxxx km
    Time Indication: 0
    Freeze Frame:
    RPM: 1875 /min
    Load: 31.0 %
    Speed: 54.0 km/h
    Temperature: 74.0°C
    Temperature: 22.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 13.970 V
    Then its definitely the thermostat. Its a fairly simple job, you will need one or 2 tools and some G12/G13 anit freeze. Take you about an hour to do if you want to do it with a bit of speed. Otherwise 2 hours maybe. Longest part really is waiting for the car to get up to temp again to bleed the system Only use Audi Oem part others tend to go faulty within 3 to 5months
    Part number: 06D121111G - Trade £23, Retail £32
    Thermostat DIY please - AudiForums.com
    The above link about half way down is the guide. You dont have to take off wires on the alternator. You can if you arent confident but I didnt.
    D2NY G's Avatar
    Apr 2011
    1,041
    Quote Originally Posted by Giosabcsl View Post
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: xxxxxx km
    Time Indication: 0
    Freeze Frame:
    RPM: 1875 /min
    Load: 31.0 %
    Speed: 54.0 km/h
    Temperature: 74.0°C
    Temperature: 22.0°C
    Voltage: 13.970 V
    Legend mate!
    Nice one yeah will get it scanned and see what the score is, hopefully sooner than later, Cheers :D
    Sep 2013
    20
    mines kind of doing the same, seems to be taking longer to warm up than it should.Its gets up to 90 then if sitting in traffic it will go down slightly. But on motorway gets up to 90 and stays there.
    I have had 3 mk4 golfs, with same prob and it was the temp sensor every time.
    D2NY G's Avatar
    Apr 2011
    1,041
    cheers guys, the problem has seamed to solve its self though, but still gunna have it checked
    Oct 2011
    6
    I have had the same problem as you for a while now - the temperature drops to 70ish while driving on the motorway and increases to 90ish only when idling ( e.g. traffic lights). Fuel economy seems to have dropped by around 3mpg too and the car seems ever so slightly less responsive.
    I scanned the car using VCDS and it didn't throw up any errors at all.
    Does this mean that the problem could be caused by the coolant temeperature sensor instead?
    Big Al's Avatar
    A4 2.0T FSI engine knackered!
    May 2011
    West Midlands
    304
    Quote Originally Posted by Skaylesh View Post
    I changed both the coolant temperature sensor & thermostat on mine to fix a similar issue.
    Audi A4 B7 2004 red 2.0 TFSI Quattro Sport saloon, Servotronic steering, MFSW, CDIS, DRL with Coming Home, auto dual xenon lights/wipers/mirrors, split folding rear seats, 3rd headrest, centre armrest, Isofix mounts, RS4 rear ARB, pedals & carbon dash trims; Audi TTS 9Jx18alloys (2 sets), Yokohama AD08 summer, Conti TS830P winter 245/40/18 tyres, TPI 15/20 spacers/lockers, Pipercross filter, GFB DV+ turbo valve, NGK BKR7EIX plugs, Osram Silverstar Xenarc D1S bulbs. Build thread
    Molnboman's Avatar
    That what was happening with mine....noticed fuel consumption was getting higher. Replaced thermostat unit....Job done!
  1. Temp gauge issue after thermostat & sensor replacement
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2013, 23:01
  2. engine temp issue? CTS or Thermostat?
    By S3featesV9 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2011, 16:34
  3. Locating Thermostat & Temp sensor
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th October 2007, 16:24
  4. External Temp thermostat
    By imported_Smudge973 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th December 2005, 20:03
  5. A6 2.5TDI V6 temp gauge falling and rising??
    By imported_Auditurbo in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 17th June 2005, 00:44
