EM TuningChris Nott
    Nov 2013
    Glow Plug- Sometime starts--Sometime dont
    I have a similar issue. I have a 2007 A4- 2.0 Tdi- B7 (125Kw). For about the last 3 months I had issues with the car sometimes starting. In the mornings its no issue, but once driven, sometimes it wont start. The glow light will not come on and the motor will only turn. After turning the ignition on and off the glow light will come on again and the car will start. (Sometimes it wont start even if the glow light comes on again). Once the motor started, often the ESP, Handbrake light will flash.....until I turn off the motor just to repeat. There is no consistency in this issue, I can drive for a couple of days without this issue and then other days it will be more common.
    A new related issue that started is, that if I are on the open road, the glow plug will start flashing and go into "limp mode" and the cruise control will not work. Just to stop and switch off the motor and restart.....and issue is gone. I also sometime feel that there is sometimes a lack of turbo boost on hot days (South African Summers)., but then other days nothing.
    I am almost sure its not a mechanical issue, but electronic. maybe a loose connection, maybe a faulty ECU relay...not sure.
    The vehicle only has 135K Km on it and never had issues. The vehicle has been diagnosed but no results, due to not diagnosing at the same time when the issue occurs.
    Can anyone HELP!!!!
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Sounds like injector problems, perhaps getting it scanned for fault codes would be a good start?
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    Nov 2013
    I have had it scanned before. The only result that show..is a boost problem on the turbo, but once again I do not think its the turbo. Other days the boost on the turbo is perfect.
    Im lost...
    Nov 2013
    Why do you think its the injectors?
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    Normally glow plug flashing indicates injector faults. Perhaps you have an intermittent boost leak on the intake system or maybe even sticking VNT blades. I'm not too familiar with this engine myself but I'm sure one of the 2.0TDi guys will soon come on to help you out.
    Nov 2013
    Cool, Thanks
  1. 2.0 Tdi GLOW PLUG LIGHT PROBLEM STARTING CAR
    By darkside in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th July 2013, 00:17
  2. Glow plug light started flashing on 09 A3
    By jimick in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th February 2013, 17:59
  3. Glow plug light (sometimes) / loss of power
    By northtim in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th November 2011, 20:26
  4. 2.0 Tdi GLOW PLUG LIGHT- PROBLEM STARTING CAR
    Last Post: 5th May 2011, 15:48
  5. The S3 likes to do funny starts sometimes hmmm.....
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2011, 13:46
