EM TuningAH Fabrications
Results 1 to 8 of 8
Thread: Advice please
    May 2011
    195
    Advice please
    Ok so posted a while back that my car was hitting limp and displaying an EGR fault even tho it had apparently been mapped out.
    ok so bought a new EGR valve and what do you know I'm still getting limp mode....
    Any suggestions. It is not currently blanked off but there is a restrictor gasket in place.
    At the end of my tether now tbh
    May 2011
    195
    Anyone before I burn it
    Aug 2013
    12
    OK..back to the start. Do yo have the standard new egr fitted? And the mapping is back to the standard? About the limp mode, when does it occur, when you suddenly floor it? The eml will be gone now, right?
    May 2011
    195
    The limp mode can kick in at any time. Normally between 1900-2500 revs
    The egr valve was replaced because of the limp mode.
    It is still mapped for performance and should have the egr delete also.
    Aug 2013
    12
    I am no too sure a faulty egr can cause a limp mode, because my egr was faulty and only the eml showed up now and then. The limp mode is due to faulty boost either by dpf blocked, turbo or vacuum. My car also hits limp mode but I am sure the dpf is the culprit. What code show with diagnostics?
    May 2011
    195
    Shows egr fault in vcds
    Aug 2013
    12
    Is it 12592 p3130 or P0299? Is the DPF removed? Can you remove the map?
    May 2011
    195
    Shows code P0403-000
  1. S3 advice please
    By V5Ade in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2004, 22:13
  2. S4 Advice Please
    By azzurro2222 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th June 2004, 20:12
  3. advice please
    By stv in forum A8/S8 forum
    Last Post: 10th June 2004, 13:25
  4. Ess Three advice please...
    By wizard in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2004, 21:45
  5. Considering buying an S3 - Advice please!
    By Rich1275cc in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2003, 08:47
