EM TuningVolks Autos
Results 1 to 30 of 30
Like Tree1Likes
  • 1 Post By sidibear
Thread: Engine getting a bit clattery when put into drive
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    2,003
    2008 B7 2.0TDi Auto. 109k
    Just recently I have noticed the engine getting a bit clattery when I put it into drive or reverse, take it back out it shuts up again. No difference if hot or cold engine. Drives fines with no issues.
    DMF replaced at 75k.
    JSD 2.59
    Synergy-Solutions
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,680
    Possibly a tired engine mount?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Oct 2013
    373
    Tiptronic or multitronic?
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    7 speed, not sure which one that is.
    If I increase the revs slightly it goes away, its just on idle with the box in drive.
    JSD 2.59
    Synergy-Solutions
    North East
    607
    Quote Originally Posted by sidibear View Post
    For what it's worth I had very similar sounding symptoms on a Golf Automatic some years back. I had it investigated by VW and by an Auto Box specialist and both parties said it was wear on the Torque Converter and that I should live with it. This was at circa 80,000 miles.
    I took their advice and I got 242,000 miles out of that car without ever doing anything to the gearbox other than changing the ATF.
    I hope this is of some comfort .
    Paul B7
    Dec 2012
    Birmingham
    295
    Visit SinghB7's Instagram Channel
    On my car I have the same gearbox 7 speed multitronic, my inner cv joints were worn and I replaced the driveshafts both sides and it stopped.
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    Paul B7, I did think of the torque converter, the gearbox is a couple of thou off its oil change, it may make a difference.
    Singh B7, its only on idle with car not moving that I hear it, no other time. I would have thought if it was the drive shafts that it would make the noise while it was moving?
    JSD 2.59
    Synergy-Solutions
    Dec 2012
    Birmingham
    295
    Sorry I mis read you'r post, mine only happened in gear D or R.
    Oct 2013
    373
    If the car is is D and it holds itself on hills with no footbrake applied its a proper auto, ie tiptronic
    If not its prob the cvt trans
    Some but not all autos have a flex plate between the flywheel and the torque convertor, these can crack.
    Ive just reread your original post and you mention DMF replaced, i thought that was a manual gearbox only thing?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,680
    I think a more reliable way to distinguish what type of gearbox the car has is to ask if it is front-wheel drive or four-wheel drive. B7 A4 automatics with front-wheel drive have a multitronic CVT gearbox with multi-plate clutch. Quattro models have a traditional auto box with torque converter.
    Using the term "tiptronic" to describe the traditional auto box is a bit of misnomer, as both types of box have a tiptronic mode.
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    Its fwd.
    JSD 2.59
    Synergy-Solutions
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,680
    Its fwd.
    In which case, I'm pretty sure it will be a Multitronic CVT. If so, then aside from anything else, it should have had its gearbox oil changed every 40,000 from new. Are you able to tell from the car's service history if that has been done? It's pretty essential to the working life of the gearbox.
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    JDP, yes, its due at 113k, I have owned the car since 6k miles and had it dealer serviced and gearbox oil changed at the scheduled times.
    jdp1962 likes this.
    JSD 2.59
    Synergy-Solutions
    Feb 2012
    West Wales
    161
    My mum has the same transmission and hers sometimes sounds horrific - it does seem to be quieter in S and louder in D. In S I'm not even sure it does it.
    One mechanic who I trust with my car completely suggested we might have to take it to Audi for a proper diagnosis - or an auto specialist - but it seems to be fine one time its started and used, the next time you start it, its horrible. It like its catching on something that is broken.
    It still goes OK and changes OK but sounds worse at low speeds.
    Oct 2013
    373
    Quote Originally Posted by jdp1962 View Post
    JDP
    Do the cvt have the dmf fitted?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,680
    Quote Originally Posted by lynallbel View Post
    JDP
    To be honest, I'm not sure. I used to have a B6 with Multitronic, and was given conflcting information about whether it had a DMF or not. I sold it before I needed to find out.
    Oct 2013
    373
    Possibly a wise move from what ive read?
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    Ok, update.
    Its in at Audi today to get the gearbox oil changed. I explained about the noise and they reckon its the DMF.
    I said it was changed at around 70K, they checked the records and yes it was indeed, on the 7th December 2011, and came with a 2 year guarantee.
    Sods f**king law isn't it, 4 days after the 2yr guarantee expired !
    I said that I reported and booked it in over a week ago, which was before the 7th, and they are looking into it.
    Watch this space.
    JSD 2.59
    Synergy-Solutions
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,680
    Ok, update.
    Watch this space.
    If you have reported the fault and brought it to their attention inside the warranty period, then they should not refuse a claim for being out of time.
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    I have the extended warranty so worst case it will cost me £250 to get it replaced. I thought it should have lasted more than 35K though.
    JSD 2.59
    Synergy-Solutions
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    They have it in and have found slack in the DMF, and want to charge me £250 for the warranty excess.
    Not bad for £1200 worth of work I hear you say.
    £250 too much for something that has only lasted 35K.
    I have put my point to them and they are looking into it. I have already typed the draft email to Audi and its ready to go if I get charged.
    JSD 2.59
    Synergy-Solutions
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    They have just got back to me, the charge remains.
    Email sent.
    JSD 2.59
    Synergy-Solutions
    North East
    607
    Email sent.
    Good luck getting this resolved.
    Kraut HO have me back buggerall when my oil pump/balance shaft needed fixing and I wrote several letters to them.
    Paul B7
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    They still have it.
    I needed a car for the weekend so they have just dropped off an 63plate A3.
    Looks like I am joining the small car club for the weekend. May have to go on the 8V forum for a short time
    JSD 2.59
    Synergy-Solutions
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,680
    We'll keep your seat warm for you.
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    I might go there and goad that my 8V A3 is the fastest and handles the bestest, its a loaner, everyone knows they are the fastest.
    Be fun driving it though, not driven a manual car for about three years
    JSD 2.59
    Synergy-Solutions
  28. #27
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,346
    Could be worse they gave me an A1, quite liked playing with the new Audi gadgets and gizmo's though loved the interface with iPhone bluetooth audio connectivity and the coming/leaving home lights were cool too.
  29. #28
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    On the whole its not a bad little car, the stop start thingy keeps catching me out and the boot was big enough to get Tracey's Xmas shopping in it.
    Still miss the ride of my A4 though.
    JSD 2.59
    Synergy-Solutions
  30. #29
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    Update.
    The dealer has donated the gearbox oil change just leaving me to pay the extended warranty excess of £250.00, a saving of £190.00.
    I am happy with the result.
    JSD 2.59
    Synergy-Solutions
  31. #30
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,680
    Update.
    Keep the good news coming, Sidibear!
  1. Replies: 0
    Last Post: 13th April 2012, 09:28
  2. TDI Engine gets cold again when idling
    By Jon_w in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th January 2010, 21:30
  3. Audi a4 1.8t getting service insp light when start
    By audia4t99 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th May 2004, 22:41
  4. MOVED: Audi a4 1.8t getting service insp light when start
    By audia4t99 in forum The Welcome Section
    Last Post: 11th May 2004, 03:21
  5. Engine gets bit stuck at 3200 rpm when not acceler
    By supico in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2004, 14:42
