Sky InsuranceChris Nott
Results 1 to 9 of 9
    Mr-C's Avatar
    Feb 2013
    Chorley
    163
    Bi Xenon bulb replacement.
    Looks like I have lost the drivers side bulb, not flickering just dead! Thing is I know its a D1S bulb but does anyone know what the OEM spec is?
    Oct 2013
    269
    No sorry i dont but from experience of changing merc D2R type xenon bulbs, get a black marker pen and mark the retaining ring as they are a real arse to line everything back up without it all falling out!
    Might be worth swapping the bulbs over as it could be the control unit thats gone tits up
    Lynall
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    654
    D1S Phillips 4300k I believe
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    Mr-C's Avatar
    Feb 2013
    Chorley
    163
    Fecking bulb working this morning briefly!! Must be a ballast problem
    Mr-C's Avatar
    Feb 2013
    Chorley
    163
    After muchio ball ache I managed to swap the bulbs and the problem didnt swap sides so it is the ballast
    rizzini7's Avatar
    Jun 2011
    654
    Is it the adaptive xenons?
    Mr-C's Avatar
    Feb 2013
    Chorley
    163
    Quote Originally Posted by rizzini7 View Post
    Yes they are adaptive xenon's.. It started working last night and stayed on for an hour or so drive, tested them this morning and I still have 2 working lights!! I have a self fixing car.
    I purposefully kinds went for bumpy roads to see if it caused any flickering but nothing.
    I did wash the car yesterday and I did wash the slam panel and up the insides of the top of the wing. Makes me wonder if water has made its way somewhere where it should not?!
    Oct 2013
    269
    Maybe a dodgy joint on the wiring loom?
    rizzini7's Avatar
    Jun 2011
    654
    I had to swap one of my headlights out due to a similar issue. Swapped the ballasts and the problem stayed on the same side. When I sold the headlights for spares the lad took it apart and the motor had come loose. So I'd try swapping ballasts first. Awkward I know
  1. Xenon bulb replacement
    By Lewis90 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th June 2012, 18:21
  2. How Do I.. Replace A Bi-Xenon Bulb, Without Taking The Bumper Off...
    By v1raj in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th December 2011, 14:38
  3. Replacement Xenon Bulbs
    By DaveA3-TDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd September 2011, 17:21
  4. How to replace a Xenon bulb???
    By alecblack in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th April 2007, 18:17
  5. Looking to replace my non Xenon bulbs...
    By kevlar in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th January 2007, 22:07
