Chris NottVolks Autos
Results 1 to 7 of 7
Thread: Oil
    Nov 2013
    Lancashire
    67
    Oil
    Ok this has probably been covered a thousand times but I'm too lazy to search, what oil? is Magnatec 5w 30 fully synthetic ok for my 170 diesel? Don't really want to go down the long life oil route I'd rather change it every 6k or so, I've always used Magnatec in the past both in my BM 320d and Lexus is200 with no issues, cheers,
    tut_gareth's Avatar
    Oct 2012
    Surrey, UK
    83
    Personally I use Audi own brand stuff as it's very good quality oil, if your car has a dpf make sure you use the correct dpf engine specific stuff
    Avnt's Avatar
    Mar 2013
    228
    I use quantum oil which tps sell. Its aparantly castrol in a different bottle but i take that with a pinch of salt. Im sure u can pick up a 5 litre bottle of fleabay for £30
    Nov 2013
    Lancashire
    67
    Cheers going to see if magnatec is dpf comparable then stick some in.
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    2,004
    Send a PM to Oilman on here, he is the expert in all things lubrication related.
    JSD 2.59
    Synergy-Solutions
    Aug 2013
    12
    If your car is fitted with a dpf, it must be spec 507 oil.
    Nov 2013
    Lancashire
    67
    Ok cheers I'll look into it
  1. My Oil Burner
    By smanning in forum Diesel forum
    Last Post: 7th January 2005, 22:45
  2. Early oil change on a new Diesel
    By DMitch in forum Diesel forum
    Last Post: 19th February 2003, 17:58
  3. FYI: Audi Approved Oils for the S3
    By DuncS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2003, 09:56
  4. Excess Oil Usage ??
    By PaulBelsham in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2003, 22:38
  5. A Home for Oil Burners?
    By danksy in forum Classic Audi Forum
    Last Post: 2nd January 2003, 16:08
