Volks AutosJMB Retrofits
    Nov 2013
    A4 Radio antenna connections - Question
    Took the Symphony II radio out of the car to replace it (as its playing up).... Discovered the Audi makes use of two antennas for AM/FM radio reception:
    ISO male (linky)
    Fakra female (linky)
    What I need to know is which (or both) of these should be amplified before being plugged into an aftermarket unit? ...I'm hazzarding a guess that both should be amplified?
    If it's both to be amplified, then I'm going to have to get something like this:
    Amplified Double Fakra to DIN adaptor (linky)
    And a converter for one of the Fakra male plugs to plug into the cars male ISO antenna:
    Fakra to Male ISO adaptor (linky)
    Am I correct in thinking this? Surely you need to make use of both antennas (they are there for a reason) to get a good radio signal pickup. It seems to me to be a very strange choice that Audi made in using two different types of antenna connector for the radio, I guess there must be a reason!?
    yorkster001's Avatar
    Aug 2010
    York
    84
    Quote Originally Posted by junglist_matty View Post
    ISO male (linky)
    I've just fitted an after-market head unit to mine using the double fakra adaptor. The car wiring loom in mine just has a double fakra connection which connected straight to the old head unit (concert 2+).
    My understanding is the car has 2 antenna's located in the rear side windows. The double fakra adaptor includes diversity which I'm led to believe allows the head unit to tune to the antennae with the best signal? This was obviously built into the old unit.
    I'm not sure why yours has both fakra and iso so the above is probably of no use. If so, apologies :-(
    A4 (07) 2.0T FSI S Line - Dolphin Grey
    Mods: Remap, DIS, Washer Bottle sensor, AUX Input, Ambient Light, Puddle/Warning Lights, Aftermarket SATNAV/DVD, VAG-COM Tweaks.
    Future Mods:
    B5 Caps, H&R Springs, 19's
  1. iPod Connectivity Question
    By Mr_Sixx in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th December 2007, 15:24
  2. iPod connection questions - A3 8L Concert
    By buckas in forum In-Car Entertainment
    Last Post: 30th August 2007, 13:03
  3. New TV & DVD-HDD Recorder - Connections questions.
    By jdp1962 in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 3rd June 2007, 19:26
  4. radio antenna problem
    By acex in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th July 2004, 10:46
  5. Radio Antennae Aerial
    By hfu in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2004, 09:25
