EM TuningVolks Autos
Results 1 to 7 of 7
    Aug 2013
    36
    Caliper bleed nipple snapped
    Hi Guys,
    My A4 is currently in my local Audi garage getting MOT'd and they've informed me that the bleed nipple has snapped off on one of the calipers :-(. They mentioned last time that it had cracked so it's obviously bit the dust. Never had one crack or snap on any of my cars before - very odd.
    Anyhow in terms of getting it replaced Audi are probably going to want me to pay for a new caliper which will be god only knows how much. I'm guessing my best option is sourcing a decent used replacement? And if I can source one will Audi fit second hand parts that you supply? The reason I ask is i'm trying to keep my Audi service history for now as the car has only done 75k and I expect the balance shaft failure at some point. I took out a warranty to cover it and this covers me to get the repair work done at Audi which i'd prefer.
    Alex
    Mar 2010
    Cleveland, North East
    200
    Quote Originally Posted by alex350r View Post
    Hi Guys,
    Alex
    Not a chance Audi will fit anything not supplied new by them.
    A new recon caliper will be in the region of £75-100, most if not all indy garages will be able to remove the bleed nipple by way of a stud extractor. Not sure if Audi would do this, they are just fitters not mechanics.
    Aug 2013
    36
    Quote Originally Posted by Cyrix View Post
    Ok thanks - I use a local VAG specialist for my wife's car so will probably use them. I take it if they can remove the bleed nipple they will just fit a replacement saving the need for a whole new caliper?
    Mar 2010
    200
    Yep, Done it a couple of times myself on calipers, quite a common problem on most cars.
    Oct 2013
    270
    Some bleed nipples are almost impossible to remove when seized, very easy to drill to far down and damage the tapered seat, what about a recon caliper fitted by any local garage.
    Good tip is to always use caliper nipple covers and always put a little grease into the covers when fitting them.
    Dec 2010
    212
    Just bleed it from the flexy it will be fine
    boost-addict's Avatar
    Aug 2011
    977
    Quote Originally Posted by sewell10 View Post
    was this sarcastic or serious, as it lacks punctuation!
  1. Speed bleed nipples
    By Alex C in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2011, 17:01
  2. Master Cylinder Bleed Nipples...
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2011, 14:27
  3. Help brake caliper bleed valve is damage :(
    By Nez in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th September 2010, 22:22
  4. Clutch Bleed nipple
    By Joe_i in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2010, 20:50
  5. Rear bleed nipple leaking brake fluid?
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th June 2008, 19:07
